alternator
04 wiring is differant.
macs may have the right diagram if it covers 65 up. if you use an autolite alt. with external reg. [hint, most regulators are marked where the wires go. i. e. i is indicator, s is stator, f is feild. alternators are marked also.]
dang i fat fingered that one up!
The old wires are not used, do what you want with them. Single wire GM and Ford Alternators are available through many vendors, I bought my last one, a polished GM from Sumitt. My NAPA guy makes up a single wire conversion piece to plug into any standard GM alternator with the two prong plug in on the top, costs about $4.00. No diea what part number would be for the alternator, just get one for like a '78 Monte Carlo with a V-8. Should also give you some selection as to what output the alternator is. One wire goes back to the ignition switch run side, and the big wire goes to the battery side of the starter solenoid, large post. I don't know if the stock voltmeter works with this setup, I use Autometer gauges. The directions include single wire alternator installation instructions for the gauge.,....
Im hoping that this thread will get some useful answers. I was stranded on the onramp today in my 64 Econoline, stalled the motor because Im still not very good at the "3 on the tree". Didnt start back up, had to bump start it. Limped home and the battery showed 11 volts running at about 2000 rpm. Same at idle. And it was dropping. Maybe it was the 600 watt stereo system at full blast, maybe it was 42 year old parts. Ive found alot of pages saying that 1 wire alts are not the way to go, and to put in a 3 wire might be difficult. Im gonna get a rebuild kit for the generator first, and see if that works. I figure it had worked since before I was born, why change it? Unless someone has a link describing how to plop in an altenator for less then $200, Im thinking the stereo can go.
hail destroyer
08-02-2016 05:37 AM
Chevy22360
04-24-2016 01:11 PM
body9599
1978 - 1996 Big Bronco
04-06-2005 12:19 PM
