Ignition keys
Old 07-15-2001, 12:51 PM
BobS
Guest
Posts: n/a
Ignition keys
I have a '88 F150 and a '99 Ranger. I would like to re-key the F150 ignition switch to use the same key that I use for my '99 Ranger. I know the Ranger uses a programmable key for security, but it seems to me the '88 should be able to use the same key. They look very similar but the new key won't go in the old switch. Any suggestions????
Bob
'66 7 Litre Convertible, top loader, 3.25 Traction-lock, 427 Sidewinder Intake, 780 Holley, Windage tray, SCJ Exhaust manifolds, H-pipe, MSD, Line-lock, AM/FM/8-Track/CB
'88 F150 XLT Lariat, 302, 5 speed, 3.08
'98 Mustang, 3.8, 5 speed
'99 Ranger, 3.0, 5 speed, 3.73 posi
Old 07-15-2001, 01:23 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
Ignition keys
Hey that's not a bad idea!!! You would probably have to order a new ignition switch which isn't that expensive, and have it rekeyed to the Ranger's key. I think it could be done, you might even be able to get the door looks rekeyed to the same key.
Old 07-15-2001, 03:23 PM
whomrig's Avatar
whomrig
whomrig is offline
Ignition keys
I like that...one key fits all.....
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old 07-15-2001, 04:44 PM
mefsh's Avatar
mefsh
mefsh is offline
Ignition keys
Re key the ignition and then use one side of the key for the 88 and one side for the 99.
Old 07-15-2001, 05:38 PM
BobS
Guest
Posts: n/a
Ignition keys
I'ver done that before and found that I often got the wrong side in the dark.
I can't get the Ranger key to go into the F150 switch. I guess I'll have to see what the locksmith has for ideas. I can always use the convertible's key. I'll post the results after I see the locksmith.
I'm changing the door locks on the F150 to use the same key as the ignition switch. I am using door locks off of a '66 Ford parts car. I hate to use two keys to unlock and then start my car/truck. I just have to figure out how to get the door panels off.
Bob
Old 07-15-2001, 08:56 PM
Rosati's Avatar
Rosati
Rosati is offline
Ignition keys
I only see one flaw in your quest to eliminate a key, the chance that one day you may loose that key and somebody getting not one but two vehicles. Or the expense of replacing all of the locks.
I just keep two identical sets of keys. This way no matter what I drive, I always have the right key.
Krosati
Old 07-16-2001, 05:52 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
Ignition keys
As far as finding the correct side of a key with two different sides I filed a notch in one side. Actually my key is for the same car. It has the '92 Aerostar's door on one side and ignition on the other. Turns out that notch up works both. Can'd do a door/ignition on older Fords (my '90 E350) as the zig zag is reverse on the door compared to the ignition. Supposedly the ignition is at the tip of the key and the door is the rest. Heard of a locksmith who had two Fords and got both card--doors and ignition--all on one key!
Old 07-18-2001, 08:10 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
Ignition keys
Old 07-19-2001, 09:24 PM
BobS
Guest
Posts: n/a
Ignition keys
Well, I finally visited the lock smith and the '99 Ranger uses "wafers" and not "pins" like the '88 F150 so the two locks can not use the same key.
I was able to switch the door locks and re-key them so the same key opens the door and starts the truck. I used the door locks from a '66 Ford.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
harryj
New Member Introductions
07-13-2008 04:32 PM
bsprowl
11-03-2001 08:58 PM
BobS
07-26-2001 05:08 PM
Quick Reply: Ignition keys
