steering gear box
steering gear box
does anyone sell an aftermarket steering gear box for a 1956 F-100 2wd?
I am wanting to put power steering on this truck but the gear box needs to be replaced.
Is it a kit that i can buy that will replace the gear box and add power steering?
This project is going to be a long process but it will be perfect when i get done.
Thanks
-Brandon-
Thanks
-Brandon-
Brandon,
Click on search near the top of the screen, then advanced search. Select the 48-60 Forum in the lower-right list box and then enter your search words in the upper-left box. Use something like +Toyota +Steering. The plus signs tell the search engine that the word MUST be in the result. You'll find quite a few threads that discuss the Toyota box and issues related to it like the hose fittings, etc. Enjoy.
Steering Conversion
Concur that you should search this site, ask a lot of questions, and learn from others' experiences. You'll find out there are many ways to get the conversion done. A lot depends on whether or not you keep your original engine. Some bracket design & fabrication may be required. If you put in a more modern V-8 or have a Y-block you can use an original bracket and power steering pump. If you use a Toyota gear box you will not be able to have your original horn button work with your original steering column. I added up the receipts for my p/s effort - $884.13 plus my own labor. Will be happy to share my parts/vendors list. Also have some photos in my gallery. Good luck.
My conversion ran ~ 500., but that included an Ididit tilt column and Grant banjo wheel. I didn't have to buy the HD tie rod or a pump and mount as they were already there on the truck from the earlier install of one of the ram power assist kits. I bought the box used for < 100.00. I also used Mid Fifty's conversion kit.
downshift
09-01-2003 08:47 PM
jcred
01-28-2003 12:55 PM
GSchretter
09-30-2002 06:40 PM
