1995 5.8 Lighting Engine Swap
All:
I have a 1993 Bronco with a 5.0 and E40D auto. I have bought a 1995 5.8 Lighting Engine and a new ECM part#
F3TZ12A650AD for a 1993 Lighting engine to replace the old one in the 1993 Bronco.
Will the wiring harnes that came with the used engine that only goes to the Fender Well have the same wiring pin-out as the wiring harnes from other half from the ECM of my 1993 5.0 Bronco?
If not how can I get a wiring diagram to correct the pin-outs?
Regards,
Rick Hawrylak
Regards,
Rick Hawrylak
Welcome Rick, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
Enjoy FTE....and
Thanks!
I have the wiring diagrams now for 1993 5.0 Bronco and it seem the same for 5.8 and 5.8 Lighting all with the E40D automatic. Pin #'s 23 Knock Sensor & 24 Power Steering Presure Switch & 43 AC Pannel Input are not used on the 1995 F- Series, but I am not sure about the 1995 5.8 Lighting yet. It seems that the wiring diagrams are suppose to be the same for all 1995 trucks. I guss I will find out soon!
sevensecondsuv
15
02-20-2019 11:21 PM
RacinNdrummin
05-31-2017 08:59 PM
Bob 79 supercab
Electrical Systems/Wiring
11-09-2013 07:31 AM
