98 ranger misfire
98 ranger misfire
i have a 98 ranger 4 cylinder with 2 coils when it rains out the truck misfires and even stops running iv changed all 8 plugs and wires also both coils still have the same problen when it gets wet runs really ruff and will even die. any ideas what to check next. what are the components that could be causing this problem for me thanks for any kinda ideas where to look
If this problem began AFTER you changed the plugs & wires, pull & check the plugs ceramic insulator's for damage, like crackes or chips.
Also check the wires insulation & routing, just beause they're new, doesn't automatically make them good!!!
Alsp try cleaning & spraying the coil pack with silicone, but don't do this with the engine running, because if it's ingested by the engine, it won't do the O2 sensors any good.
If that fixes or changes the problem for the better. you probably have a coilpack encapsulate problem, like a crack or air bubble close to the suface.
Let us know what you find.
this problem was why i changed thess parts still had same problem so plugs wires and coils are ruled out. do i need to change the powertrain control module ? or can crankcase position sensore or what im going nuts cant drive my truck cause its so wet out also seem to get really bad going up a hill it will stop running alltogether. have to get running and hold throtle half till fires on all four then soon as i try to go misses again seem to miss worst when i turn the wheel or any kinda load on the engine keep in mind when its dry out truck runs good
truck ran great today finally dried out. so i took a hose the the engine compartment didnt change anything still ran good. came back 1 hr later truck was undriveable missing like crazy check engine light flashing was pulling injector wire off one at a time ang #4 cyl had no power pulled plug wires off one at a time and they all are fireing with good spark. im thinking now its fuel injectors is this my problem ? 168K miles 2.5 engine. iv changed the fuel pump assembly now with no change. to hard to get to the injectors to do an ohm test
