105 cast backwards on clock
Other than it's a late model FE block, Nope. Could be a 360 or 390. I think the FT engines also had this block. The only way to know for sure is to pull a head an measure the bore and stroke. Short of that you could use a dowell to measure the stroke of the piston through one of the spark plug holes. Measure at TDC and BTC and subtract. 3.5 inches = 360, 3.75 inches = 390 assuming a 4.05 inch bore.
The reverse image 105 block has a little more meat in the bottom of the block. Some consider this a better block to build on. Mostly used as 360s. 360s are 390 bore blocks, so yours could have been built as a 390.
I saw a 330 FT block yesterday that the 352 on it.
72, I like to put a 8" long white house wire into one of the front plug holes and have a bud rotate the engine a couple revs while I hold a Sharpie on the wire. I can measure the length of the mark for the stroke. Aint gotta worry bout the rithmetic that way.
John
John
Some service replacement blocks didn't come built as any engine size from ford other than cylinder bore. A bare block could be ordered from Ford and lacks a partial VIN. There are complete engines that came via the same route, but if the engine is all original then the cast dates are always very close for block,intake, heads, crank, etc... If you have a newer cast date (say D4TE like mine) on a mirror image 105 block than all of the other parts of the engine than the chances you have a service replacement block are fairly good.
There are no absolutes in Ford engines, so anything I stated could be argued either way.
The reverse "105" blocks replaced the "352" blocks around 1973. They were cast at the new MCC Michigan Casting Center. Some 105 blocks have the thicker cyl walls and some do not. The drill bit test through the freeze plugs will confirm which it has. They all have the HD crank webbing of the earlier HD blocks.
G.
G.
cies_69_ford
01-15-2012 09:44 PM
drew.law
01-23-2011 05:23 AM
ford390gashog
21
07-03-2004 01:23 AM
mudracin74
13
06-28-2004 03:08 PM
