81 f150 turn signals not working
Old 05-28-2005, 12:36 PM
dpc's Avatar
dpc
dpc is offline
Ok, got this f150 for free. it had been sitting for 3 years in a feild and had condensation buildup all over inside. The headlights and tailights/brake lights work as do the hazard flashers but the turn signals dont. could this be inside the collum itself. I am new to F150s so i dont know what to expect fom them.
Thanks
Old 05-28-2005, 12:54 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 05-28-2005, 06:34 PM
F3Beam's Avatar
F3Beam
F3Beam is offline
Did you check the bulbs, make sure they have a good clean connection? Sometimes electrical connections just lose good contact. Some WD40 helps get the juice going at times.
Old 05-28-2005, 08:53 PM
Holmesuser01's Avatar
Holmesuser01
Holmesuser01 is offline
You are aware that there are 2 flashers on these trucks. One for 4-ways, and the other for turn signals?
Let us know...
Old 05-28-2005, 11:42 PM
dpc's Avatar
dpc
dpc is offline
thanks for the quick responses. I wasn't aware of there being two flashers since I only saw one in the fuse box.Tell me where the other may be located and I will check it out tomorrow as well as the bulb contacts. thanks again
Old 05-29-2005, 12:30 AM
Holmesuser01
right behind the one that you found
Bulbs are OK since they work with brake lights, and the reg. tail lights are ok
Old 05-30-2005, 10:39 AM
dpc's Avatar
dpc
dpc is offline
ok, so the other flasher is ok too. now what do I look for? Could it be the switch in the collum or something else.
Old 05-30-2005, 03:48 PM
Darren M.'s Avatar
Darren M.
Darren M. is offline
Where are you located? There are some great people on here and one of them might be close enough to swing by and take a look for you.
Old 05-30-2005, 03:49 PM
Holmesuser01
Did you swap the signal flashers to check them? Thats what I would do...
Old 05-31-2005, 12:31 AM
dpc's Avatar
dpc
dpc is offline
Ok I first swapped the flashers for new ones I had laying around with no change. So I started to trace the wiring around to see if I could find anything. This truck was a farm truck and some stuff was done very questionable. The truck has a trailer brake system on it that is the old style and it is wired directly into the fuse box. I first looked there then I got curious about this little blue toggle in the dash. I traced the wires from the toggle right through the firewall and down under the cab where they splice directly into the OEM wiring going to the rear. I still dont exactly know what the toggle does but on a long shot I noticed that it had frayed wires that were grounding out on the steering collum support and it was popping a fuse under the dash. I thought the fuse was for the radio because it also works when you put a new fuse in. Like I said, its not quite wired the way it should be. Anyways the blinkers work now and I still dont get the toggle switch.?.?.?.? oh, I also wired a relay in for the fuel pump because the wire was also just stuffed into the fuse box next to a fuse.thanks for all the help
sinmike
10-10-2013 06:26 AM
Krisverde
08-06-2013 11:06 AM
islapp
2009 - 2014 F150
08-07-2012 09:37 PM
compwrench
1997 - 2003 F150
06-25-2012 04:45 PM
ChurchBuilder
10-27-2006 09:00 PM
Quick Reply: 81 f150 turn signals not working
