223 I6 engine oil
I wouldn't use a none detergent oil in any engine . The 223 was a sludge maker, and using an oil which isn't HD would just add to the problem. I think i'd rather use 10-30
than 10-40. I had a 59 F100 with a 223 in it worked it hard for 15 years engine worked
fine. After a while the timing chain will talk to you, but thats no big deal to
replace, and you will have to adjust the valves if they get noisey, .019. I took care
of a few of them in the fleet I worked for, to bad the bodies didn't last.
Is this an F-100? Click the picture below for a scan of a lube chart. Let me know if you can't read it. I have a hi-res copy.
According to the chart you'll need 5 quarts of SAE 30 for temps above 32 degrees. Not sure which of today's multi-weight oils would be best. Kotzy's recommendation of 10W-30 would probably work. If you don't trust the chart, put four quarts in, run the engine for a few seconds and check the dipstick.
Hope this helps!
Kevin Kessler
1953 Ford F-100
Go Illini
Hope this helps!
Kevin Kessler
1953 Ford F-100
Go Illini
scaraj
53
07-21-2021 02:28 PM
SonyResendiz
Vendor Specials, Discounts, Product Announcements & Group Buys
02-26-2017 09:59 AM
NateTheGreat
10-22-2015 04:11 PM
taylor90
02-22-2012 04:30 PM
