99 ranger whining/whistling noise
Old 05-11-2005, 11:02 AM
fordlvr25's Avatar
fordlvr25
fordlvr25 is offline
anyone else this problem, driving along and you can hear a high pitched whining noise, sounds like it is coming from the drivetrain.
Thanks
Old 05-11-2005, 03:45 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
I've heard of the PVH hubs making a whistling sound when they haven't been used in a while, even in 2WD.
Do you have 4WD? If so, next rainstorm be sure to engage the 4x4 system and drive around for a little, see if that helps with the noise.
Old 05-12-2005, 07:21 AM
Phitty's Avatar
Phitty
Phitty is offline
I have a 2000 B4000 with the PVH Hubs.
My truck does the same thing - especially in the spring and fall, and never in the winter (when i use my 4x4 more often). I think it may also be related to moisture/humidity levels but thats just a theory. Im not sure what the sound is but I think its a rubber squealing sound from a dry seal or something.
Turn on your 4x4 and listen to see if the noise decreases or goes away entirely. Its not a permanent fix but makes a difference for a day or two.
If I use 4x4 alot then the whining goes away for a longer time.
Hope that helps a little. If you find a better solution make sure to let use know.
P.
Old 05-12-2005, 08:08 AM
fordlvr25's Avatar
fordlvr25
Whining noise
So as of right now there is no fix for it. it is just so annoying when you are driving next to someone and you can hear it. but we have concluded that it is probably with the 4wheel drive system, can you grease or lubricate anything up there so it wont do that...
john hardy
1999 to 2016 Super Duty
19
01-08-2022 02:44 PM
Josh Toomey
04-17-2017 08:01 PM
chuck2629
2004 - 2008 F150
11-09-2015 07:13 PM
meck1
07-19-2010 09:34 AM
Ray_K
01-24-2006 11:18 PM
Quick Reply: 99 ranger whining/whistling noise
