2003 Explorer Rear End Whine solved
Old Nov 26, 2005 | 01:58 PM
Ray_K's Avatar
Ray_K
Another post about an explorer with a rear end whine. After pulling it apart once and changing some parts (clutch pack) with no change the dealer agreed to replace the entire differential with a new one. It's quiet now and I hope the replacement will not develop the whine again. The original only had 45000 Km on it. The whining noise on mine was during acceleration between 80-95 Kmph. If you let up on the throttle the noise would stop. Don't let them tell you your tires are noisy if your convinced it's the rear end.
Old Dec 1, 2005 | 07:12 PM
FortyFords's Avatar
FortyFords
From your description a noise like that is the carrier bearings in the rear diff.
Glad you got it fixed.
Rich
Old Dec 1, 2005 | 08:20 PM
Ray_K's Avatar
Ray_K
I'll keep that in mind if it develops again after my warranty runs out. From the dealer's perspective I guess it had already been pulled apart once and to do again versus replacing unit was better for them. I wasn't going to argue. I wish they would do that with my tranny. It's going in again next week to have them pull it out again for the third time in a month.
Old Jan 24, 2006 | 11:18 PM
hppydrunk's Avatar
hppydrunk
Same thing happened to me.
Same thing happened on me on wifes 03 XLT 2wd. Dealer kept trying to say that it was everything else. Knew it wasn't. There troubleshooting guide only has two actions Diff replacement is the the second. Bad news is 50,000 second diff is starting to whine, so I'll start this all over again.
F150MUTT
2015 - 2020 F150
Aug 12, 2017 02:29 PM
IIGood
Mar 17, 2016 05:59 PM
Railroad02
New Member Introductions
May 30, 2008 07:47 PM
fischone
2004 - 2008 F150
Jun 24, 2005 09:28 PM
mxz7
Feb 18, 2003 07:20 AM
