1985 f150 4x4 rear end info needed
[font size="1" color="#FF0000"]LAST EDITED ON 03-Jul-00 AT 03:30 PM (EST)[/font][p]The Ford 9" has many different gearing options available. Ring and Pinions vary anywhere from 3:00.1 all the way to 6:50.1 ratio's. Also, depending on what gears you want, there are different carriers needed. I don't know the specific ratios, but the surface that the ring gear bolts on to will be in different places depending on the thickness of the ring gear. Most 4 wheel shops, or rear-end shops should be able to tell which ratios will require a different carrier.
Also, if the gearing is changed to a different ratio, be sure to change the front gearing as well.
1985, 4x4, differential, differwrenchel, end, f150, ford, free, gear, information, ratio, rear, rearend, specs, truck
