Carb for 1977 F250
Carb for 1977 F250
I have a 1977 F250 with the original Motorcraft 4350D carb on it. This carb is pretty worn out and I would like to replace it. My question is... What carbs will fit on the stock manifold? I am guessing a Holley 3310 series but I would like to retain the stock fuel line and accelerator linkage connections. I also want it to pass smog check II in California.
What have other people used?
Thanks!!!
John
Thanks!!!
John
I'm not familiar with that particular carb number and you don't say what engine you have. If it is a four barrel, most any four barrel will fit and the aftermarket carb makers have Ford a/t linkage kits.
If it's a two barrel you're limited to a Holley two barrel, stock carb or change the intake manifold to an aftermarket 4bbl unit.
Good luck,
Doc
Good luck,
Doc
Spreadbore pattern
OK, I took the carb off and traced the gasket. Yes, this is a unique pattern spreadbore. It appears that a squarebore pattern will work with an adpater plate or a thick gasket. The original carb is simply worn out. I wanted to go with a Holley replacemetn and was wondering what other guys have done with a stock 460 manifold and different carb.
John
John
JDBeck23
06-18-2017 10:25 AM
wcasey
11-04-2016 07:48 PM
qthews
12-07-2015 12:57 AM
Teagar
09-02-2006 03:32 PM
