1960 F250 with 223 came with 8HA Carb?
Everywhere I have seen (online) it states that the stock carb for the 223 I6 is the Holley 1904. The truck I just bought had the carb in a box with a few other things. After about an hour of research, I finally figured out that its a Ford 8HA 1 barrel carb for a flatty 226.
Any chance that this carb would work on my 223, or was it simply tossed in the box?
If this carb is no go, is there a decent used market on Holley 1904s? What should I look out for?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Funny enough, both hiball3985 and timan52 are correct. The 41-47 flathead six motors, the G series, did not use the LOM distributor so their carburetors don't have the vacuum port. The 48-51 six motors, the H series, did use the LOM setup so those carburetors do have the vacuum port. Since you said your carburetor is an H series it should have the vacuum port.
I prefer the 847 Holley to the 1904 Holley myself. The later 1904 is shorter for clearance with lower hoods, but I don't think it was an improvement. The atomization of fuel in the later 1904 is much cruder, the power valve isn't replaceable for tuning, and that really cool looking glass bowl setup likes to warp and leak. I'd run an 847 on my 53 sedan if it would fit under my hood.
pntrbl
52
01-13-2006 10:08 PM
Chtulu473
08-21-2003 09:53 AM
bartfc
11-13-2002 08:04 PM
