35's on stock suspension
There is a chart on the red linked page in my signature that lists the tire sizes and amount of lift that is commonly "doable" without rubbing. 35's WILL rub on raduis arms, fenders, AND front bumper on just about every model Bronco with OEM suspension. The ONLY exception MIGHT be a 78-79 model with brand new springs under it.
What width rims do you have? I'm pretty sure from all my references that you will need at least an 8" wide (probably 8.5") for the 11.5" tires. Also remember that your suspension has travel and check out the tires and their travel as well as you can prior to heading to the woods. If it's in Streaks FAQ's I'd bet on it being correct.
The final answer is, yes you can do it; and no, I don't recommend it without a lift. I've seen it done, the poster above said that he did it too. I personally do not like the way that it looks, but that is a matter of opinion. And with no lift and 35's, you can be sure that if you do some heavy off roading with a lot of rocks and bumps, you are gonna rub all over the place and perhaps even gouge the tires to the point of ruining them.
In the real world, don't go any higher than 31's if the truck is stock, with stock wheels. Just because something _can_ be done doesn't mean that it _should_ be done.
Originally Posted by spitdriver
I looked over the FAQ's and it says I can put 32's on my Bronco without a lift. Will these fit my stock rims? The tire size I would need is 32/11.5-15.
FordYoungGun35
27
10-16-2013 02:03 PM
460 Guy
18
10-19-2012 06:26 PM
