86F150 frontend shakes at 55 and when it brakes ?
Old 07-07-2001, 06:58 PM
mikehaey's Avatar
mikehaey
mikehaey is offline
someone told me the bussings are bad but with ones??
Old 07-07-2001, 10:06 PM
jakegypsum's Avatar
jakegypsum
jakegypsum is offline
You really need to check everything out including your rims and tires for balance. Check your shocks and shock bushings for wear. Check your wheel bearings for slop. Check all suspension hardware for wear and looseness. Steering components could possibly do this but most of the time I have seen problems like this be suspension related. Good luck. Jake.
Jakegypsum // Ford fleet, soup to nuts.
Old 07-08-2001, 03:09 AM
bgodkin's Avatar
bgodkin
bgodkin is offline
Definatly agree with Jake, I have found Tie rod ends to be the culprit on My Trucks Ford uses some really cheap ones from the factory. grab the front tire and shake it from front to back like You are trying to rip it off the truck. You shouldn't get any movement. If You do get someone to look under it while You do this and see whats moving. Hopefully this will help. Could also be a flat spotted tire anywhere on the truck. I have chased down front end shakes to a flat spotted rear tire before.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old 07-08-2001, 04:08 AM
mikehaey's Avatar
mikehaey
mikehaey is offline
thanks jake man someone told me about the right shock leaking at the top might be it man thanks
Old 07-08-2001, 04:11 AM
mikehaey's Avatar
mikehaey
mikehaey is offline
thanks brad will be looking around the truck now thanks man
Old 07-08-2001, 09:56 AM
deere81's Avatar
deere81
deere81 is offline
Check your tires for knots and have your rotors turned. Warped rotors could be your braking problem.
Old 07-08-2001, 12:56 PM
bgodkin's Avatar
bgodkin
bgodkin is offline
No prob Man, Let us know what You find out.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old 07-08-2001, 01:08 PM
brett_d's Avatar
brett_d
brett_d is offline
I agree with deere81.. I would definetly not count out the rotors. Unfortunately this is hard to just check. If everything else check out fine you may have to take the rotors off and have them turned. Sometimes you can tell rotor warpage by discoloration of the rotor. But not all the time!!!
1988 Ford F250 4x4, 5.0 liter (soon to be Roller 5.0), AOD tranny, 2.5 Dual exhaust, Headman Shortyheaders, 33" BFG's Mud Terrain
1980 Ford F100, with 1988 5.0L Roller (carburated), T-5 five speed Borg Warner World Class Transmission, 31 spline 9" 3.73 posi , and a bunch more!! 13.78 quarter mile.
Old 07-08-2001, 01:13 PM
jakegypsum's Avatar
jakegypsum
No prob, Mike.
Tire problems like Brad mentioned about flat spots and also knots like Deer81 talks about can really give you the run-around also. I also agree with this being a problem on the front or rear of the truck. Defenetly check any tires in question. Good luck. The vibration would speed up and slow down with conjunction to the speed that you are traveling. Good luck. Jake.
Old 07-15-2001, 04:12 PM
mikehaey's Avatar
mikehaey
mikehaey is offline
jake I checked the brakes they where shot so replaced them then on the right side the shock nut on top was striped so put some washers and new nut dont do it no more thanks alot foryour help
Old 07-15-2001, 08:24 PM
jakegypsum's Avatar
jakegypsum
Smooth. Glad to be of service. Jake.
Old 07-15-2001, 08:27 PM
fatforty's Avatar
fatforty
fatforty is offline
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 86F150 frontend shakes at 55 and when it brakes ?
