stock radiator with new auto trans.??
Ok,
I made a decision based on what I want in my truck. Im going to have my radiator guy rebuild my stock radiator- core tanks and all. Im going with a remote mounted trans cooler as well. I called around, and talked with the fellas here in San Diego Chapter of Pickups Limited (which I attended my first meeting last night ) and decided to go with the stock setup.
One thing I took into consideration was the fact that even with a leaky radiator, my engine was still nice and cool, no matter what. The radiator guy (who happens to be a Ford rod builder, and an old timer to boot) told me my radiator would look and work like it just came from the factory, and that he guarantees all his work. Bottom line is that the guy was really friendly, and I trust him. I was also told by every vendor that I called that $265 for a new stock radiator rebuilt or not was a good deal.
Thats my story, and Im sticking to it.
P.S. The guys and gals here in the San Diego Chapter of Pickups Limited are a GREAT group! Im looking forward to functions and cruising with people who love their trucks as much as I do.
Once again, Thanks guys!
Rich
Rich
on
Originally Posted by MO51
I've got 20 years on a 289/C4, using the old stock 1951 F1 radiator and a cheapo JC Whitney tranny cooler in front of the radiator. Works fine.
Vern
Vern -
I'm with Randy Jack, I personally don't have the original in my, however I have several friend who do. They all state they run no higher than a 7 lbs cap. One friend of mine had the entire core replaced when his fan came loose and pretty much ate the core. He had a heavy duty core put in, but the radiator shop told him no to use a higher pressure cap. Apparently it's the design and strength of the upper tank that will split or separate with higher pressure. I'd stay with the 7 lb cap. or put a nice aluminum radiator in your truck and give me your radiator..... Smile!!!!!
Ok guys,
I guess Im not sticking to my original story. Im back to square one, and still looking for a replacement radiator. Today Im in the aluminum mood. Man I wish I wasnt so indecisive. Im gonna keep checking around,and hopefully figure out something nice that I can afford. I just want to make the best decision, and not have to do everything twice like some of the kind gentlemen on this board
Hi John!
Rich
Hi John!
Rich
I can't decide if I am indecisive or not, but I will cast one more vote. I like the Modine replacement over aluminum for no other reason than repairability, I like stuff I can fix (read solder) on the side of the road if I have to. That has always been the bottom line and has never let me down. I have expressed myself and now I feel better, I think.
I would have to agree with Fatfenders 56. Although I don't know much about the custom aluminum radiators other than they cool really good and look sweet, having the Modine radiator is definitely more practical. He has a good point about the solder and I've been there more than once. With the aluminum, you get a leak, your in trouble. Good point! If money is an issue, I wouldn't even think twice and go with the Modine or just repair yours.
#28
A really deluxe set-up (IMHO) and one that addresses 51dueller's very legitimate concerns about over-cooling (you don't need to be at -100 F to have that problem ) is to install a thermostatic valve in the line after the stock tank cooler. These are made by several of the aftermarket cooler guys. When the tank cooler is doing all that's needed, no flow goes to the air-cooled auxiliary cooler. When it starts climbing above that (I think it's about 160) it diverts the oil thru the air-cooled. The thermostatic valves are very compact, take up no room to speak of and can be retrofitted if you already have an aux cooler.
I used to run only an aux cooler (air-cooled) on a car in Chicago and the shift points would change dramatically when it was in the 20's all day. Unless I ran on the highway, it just never got warm enough (I had a large aux cooler, which you need if you're only running the aux).
finitetime
12-05-2011 07:14 PM
woodn1
03-11-2010 07:51 AM
55forder
22
05-06-2005 02:40 PM
