302 HO or Not ?????????
Old 01-28-2002, 07:18 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
Old 02-03-2002, 07:29 AM
JJH's Avatar
JJH
JJH is offline
[updated:LAST EDITED ON 03-Feb-02 AT 08:47 AM (EST)]I recently purchased a complete engine that was advertised in the paper as a 302 HO froma 83 Mustang. I am just about ready to start reassembling the engine after boreing the block and buying all new internal parts. I was in the parts store the other day and this fellow I was talking to told me that Ford did not make a HO in 1983. That the engine I have is not a HO. First of all what is the difference between a HO and a regular 302. Second, How can I tell if it is a HO. The engines breather read 302 HO 4v, the valve covers are the aluminum type, double sprocket timing chain, 4 bl Motorcraft Holley. What else can I check to be sure which I have before I start assembling the engine? Also how many cubic inches will a 302 bored 30 thousand over be?
Thank
Jerry
Old 02-03-2002, 11:37 AM
rc351w's Avatar
rc351w
rc351w is offline
Boring .030" over will give you 306ci. As for the HO, I think the HO 302 had a roller cam.
RCC
Old 02-03-2002, 03:27 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
The "HO" 302 came out in the 1982 mustang. It had a double roller timing chain and a slightly higher lift cam. It still had a 2bbl carb and was rated at 157hp. In 1983 they still had the HO 302, but added an aluminum intake manifold and 4bbl holley carb. Horsepower for 83 was 175hp. You have to remember, HO 302 in those days was a big deal in a new car. The horsepower choices for the previous years was terrible, so the little effort the factory put into the 302 those years and the "High Output" designation was a big change. Looking back on it now, those engines were not much to brag about horsepower wise, although they were the beginning of what we have now. So historically you have a nice engine if you keep it dressed out like it was originally. But you could make major improvements on it with some aftermarket parts.
Old 02-03-2002, 05:19 PM
mustange70's Avatar
mustange70
mustange70 is offline
I believe that a 302 HO with also havee true flat top pistons. This reminds me of something, I saw a 302 HO in a 87' Lincoln Mark VII. How much power will this have?
82' Flareside with 400 horse under the hood
Old 02-06-2002, 12:32 PM
mantta's Avatar
mantta
mantta is offline
The firing order is differdnt on a 302 HO. On the regular 302 the firing order is 1-5-4-2-6-3-7-8. On the HO engine it is 1-3-7-2-6-5-4-8. On the HO for the models around 1990 there is 75 more horsepower in the HO engine.
Old 02-06-2002, 02:07 PM
JJH's Avatar
JJH
JJH is offline
I have changed the cam to a little stronger one and had some head work done. Also have added roller rockers and eliminated the smog stuff. Bored .030. Will the fireing order be different now than before?
Thanks JJH
Old 02-06-2002, 05:20 PM
mantta's Avatar
mantta
mantta is offline
That depends on what engine the cam was made for, the HO engine or the standard 302.
Old 02-06-2002, 07:49 PM
Franklin2's Avatar
Franklin2
Some of the HO's had the 351w firing order (this is the firing order previously mentioned). Some aftermarket cams have the 302 firing order, some have the 351w firing order. It is possible to have a 351w with a 302 firing order, and have a 302 with a 351w firing order depending on what you have installed. You had better check the part no. of the cam you installed so you know how to hook the sparkplug wires up (swapping the plug wires around is all you have to do).
Old 02-07-2002, 11:05 PM
390GT's Avatar
390GT
390GT is offline
actually 82/83 are pretty much the same...a block revisal mid year.and it'll have the 351W firing order...marine cam 260int and 273exh duration, .416lift intake, .444 exhaust.
82 had aluminum 2bbl and 83 had aluminum 4bbl.
175hp @4200rpm..
it does NOT have flat tops from factory its only 8.4:1 compression and cast pistons..but if its been bored then that could be altogether different...its a good start though.
Old 03-04-2013, 10:32 PM
Southern kicker's Avatar
Southern kicker
Southern kicker is offline
1988 ford bronco 302
What is the firing order on a1988 ford bronco 302 and where is the number 1 piston located
Old 03-05-2013, 06:53 AM
Franklin2's Avatar
Franklin2
#1 is the front passenger side cylinder.
Old 03-05-2013, 11:41 AM
mudgepondexpress's Avatar
mudgepondexpress
mudgepondexpress is offline
And don't forget Ford numbers it cylinders down the side (passenger) first, so PS side is 1,2,3,4, Ds is 5,6,7,8. Our GM friends like to number from front to back (PS side 1,3,5,7, DS 2,4,6,8). I have seen many a GM person put the plug wires wrong on their first Ford.
Kenny
Old 03-05-2013, 11:45 AM
Franklin2's Avatar
Franklin2
I don't know if you realize this, but the GM method makes sense, the Ford method does not. GM starts with the front most cylinder and calls it #1. Then looking at the crankshaft, they go 1 2 3 4 5 6 7 8 to the rear of the engine. A v8 alternates which cylinder goes to which cylinder bank, so that's why one side is odd and the other is even. I don't know how Ford came up with their numbers.
Old 03-05-2013, 04:08 PM
mudgepondexpress
I understand the theory on why GM did it that way, but it doesn't make one more right than the other, just different. They could have numbered them from the back to the front, or from distributor to the other side.
I like the Ford way of doing it, but then I have been working on them since I was 14 years old.
Kennyu
bradphx
67
01-10-2024 06:12 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Oklahoma Chapter
04-11-2003 10:33 PM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: 302 HO or Not ?????????
