86 F150 Headlights flicker
Go to http://www.fordtrucks.com/article/id...r_Brights.html
this article will tell you how to fix it.
nhawki00, Check the wiring assembly plug that connects to the tabs on the bulb. The wire contacts inside the plastic plug may have loosened up and slid backwards into the plug. So even if the plastic plug is firmly connected to the bulb, the internal power tabs in the plug may not be making full contact with the bulb tabs. Firmly push on the wires toward the bulb so that the contacts in the plug hook up with the bulb tabs.
BOthatGAboy
02-19-2013 08:53 PM
HOODRAT
05-30-2012 06:14 PM
