headlights and dashlights flickering
Old Aug 10, 2007 | 02:38 PM
Ranger4.0L's Avatar
Ranger4.0L
I have a 90 ranger 4.0l engine.
headlights, dash lights and guage in dash, flicker at ide speed in drive and in park then they stop when stepping on gas eny ideas welcome
Old Aug 10, 2007 | 05:47 PM
Franklin2's Avatar
Franklin2
Do you have a seperate regulator for your charging system? If so, make a ground wire and bolt it to one of the regulator mounting bolts, and then run it over and bolt the other end to the engine. This usually takes care of the flashing problem.
If you have a integral regulator on the back of the alternator, you may want to unbolt it and make sure the connections are ok, and make sure the bracket the alternator is bolted to is not corroded where it bolts to the engine.
newfordy
1997 - 2003 F150
Nov 9, 2014 06:29 AM
erikwi
1983 - 2012 Ranger & B-Series
Oct 4, 2012 07:11 PM
Michael1181
Feb 8, 2011 03:46 AM
danger ranger003
Mar 24, 2005 06:45 PM
GeneStoner
25
Nov 8, 2003 10:24 PM
