With the top off and the windshield screws out it should lay forward. A couple of possibilities are a rusted hinge, bond between the windshield frame and the body, paint in the hinge. You may try some penetrating oil or spray to break it up.
Does it attempt to move at all or is it solid?
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
