Can I gut my cat and still pass emission test??
Old 01-31-2005, 04:33 AM
pullnit's Avatar
pullnit
pullnit is offline
Hi All
I have a early 99 powerstroke. I live in N.Y. We have emission testing on our diesels. If I gut the cat would it still pass the emission test??
Thanks John
Old 01-31-2005, 05:35 AM
blackf3504dr's Avatar
blackf3504dr
blackf3504dr is offline
Do they do a "sniffer" test on the diesels or just a visual too make sure it's there ?
Maybe someone from Ny. knows for sure .
Old 01-31-2005, 07:48 AM
Subsailor1127's Avatar
Subsailor1127
Subsailor1127 is offline
I can't even catch the cat. Ooops, not talking about that cat are you?
Old 01-31-2005, 09:36 AM
RobertJohn's Avatar
RobertJohn
RobertJohn is offline
Well from what I understand the late model '99's ( 99.5) didn't even have a cat so why wouldn't yours pass if the others didn't even have one ??
And the later models '00 on up don't have them either.
Old 01-31-2005, 10:47 AM
basstardo's Avatar
basstardo
basstardo is offline
That's actually not entirely correct. The 99.5 to 04 PSD's with a manual trans have a cat. The automatics do not. I don't know who the genious at Ford was who had that idea, but it's true.
Old 01-31-2005, 11:37 AM
RobertJohn's Avatar
RobertJohn
Well, if the auto's don't need one the manuals don't and the early 99's manual or auto don't need one ....... hence to and therefore.........diesels don't need cats...............
Old 01-31-2005, 11:47 AM
blackf3504dr
Angry
I'll admit Ford does some funny ( strange ) things .....But it's not thier call what does or doesn't get a cat , it's up to the ALL KNOWING EPA !!
Old 01-31-2005, 01:39 PM
mech2161's Avatar
mech2161
mech2161 is offline
I've got a 2000 6spd, it came with no cat....
Old 01-31-2005, 01:53 PM
ColtM4's Avatar
ColtM4
ColtM4 is offline
Assuming they do a load test on some rollers, you may be able to pass without the cats guts, but I suppose that would also depend on how they drive the vehicle on the test machinery. From what I understand, the reason the 6sp has a cat is because you control gear and not a computer to prevent conditions that would produce black smoke. It is a lot harder to get black smoke out of a stock auto truck than in a manual. Not the answer you want to hear, but you may be able to pass it.
Old 01-31-2005, 02:21 PM
basstardo's Avatar
basstardo
https://www.ford-trucks.com/forums/s...ght=diesel+cat
That thread has some more information. I used to know the years that had them and didn't, but that's an old old post. I'll see if I can't dig it out. I do know that mine had a cat, which is now gone. A few of my friends have PSD's that are Auto and they don't have cats, with stock exhaust. So I guess it might be hit or miss.
Old 01-31-2005, 08:53 PM
akpwrstrk's Avatar
akpwrstrk
akpwrstrk is offline
Look on the passenger side valve cover. There is a white sticker with orange writing. It has all the emission data on it, as your truck came from the factory. If this sticker "falls off," there isn't any way for the emission tester to know how your truck came from the factory. My 99.5 auto didn't have one. I know of others who have passed in Colorado without the sticker and no cat. Remember, there can be a hefty fine if messing with federally regulated emission crap. Your call. The measured emissions in Denver/Co Springs area has never been above federal regs. They are trying to do away with the program in El Paso county, however the county commisioners and emission czars are fighting it. The whole emission program is another bureaucracy to make states more money. Once the animal is created it's hard to dismantle. Just more muslix eatin, stool watchin' hippie crap in my humble opinion.
Old 01-31-2005, 09:20 PM
18vtx00's Avatar
18vtx00
18vtx00 is offline
Angry
here in MA there is a supposed $10,000 fine for removing cat converters. it must be physically there, and if you fail the OBDII test and there is a transient test, it will most likely fail.
also all trucks here above 8500GVWR require tail pipe testing, if they only do a 2 speed tast, that does not check for NOX gases, but again it is supposed to be physically there.
i think NY is doing the same MA31 transient tests as we are.
reason for the tail pipe test over 8500GVWR is the federal government gives our state $600 for each tail pipe test we do. SOME HOW WE AS THE SHOP ONLY GET A LOUZY $29 TO DO THE DIRTY DEED, NOT BAD FOR 45 MINUTES WORK AND TO INHALE HARMFUL GASES HUH!
good luck man it is not worth it here, then if you sell the truck and it does not pass emmissions, the seller must fix it for a sale price over $699, i guess i should move north or south.
Old 02-01-2005, 02:55 AM
pullnit's Avatar
pullnit
pullnit is offline
Thanks for all the great info. If I were to do the mod. I would leave it in place and gut it. Do the non cat later 99 and up powerstrokes use the same emission standards or do they have to enter another machine standard for the test??
Thanks John
dlquinton
02-15-2015 08:39 AM
TexasMarkIII
08-29-2014 02:22 PM
gg1968
06-05-2014 08:29 AM
Pridnjoy
04-13-2014 12:09 PM
IDIDieselJohn
11-16-2010 11:20 PM
Quick Reply: Can I gut my cat and still pass emission test??
