Mercon SP Tranny Fluid
#46
#49
ok ill post all of this again especially after talking to the engineers for trans and drivetrain development at ford last week about this subject that keeps popping up everywhere and most likely by the same individual who keep getting proven wrong time and time again. LV IS THE REPLACEMENT FLUID FOR SP but you can use either or.
this is the last ssm that ford posted on the matter.
Ford Special Service Message 21114
MESSAGE TITLE: REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
APPLICABLE VEHICLES :
2003 - 2005 TRUCK : 00126 EXCURSION
2003 - 2008 TRUCK : 00028 F-SERIES
2004 - 2008 TRUCK : 00016 E-SERIES
2006 - 2008 TRUCK : 00175 F-SERIES MOTORHOME
2006 - 2008 HEAVY TRUCK : 00168 LOW CAB FORWARD
OASIS MESSAGE :
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND 2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP. THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
This is right out of the service manual on line and this is updated day to day
OASIS MESSAGE :
#50
Thanks guys. Very helpful. I'll do a flush. FYI, I was able to trace the bucking to an ignition issue. Coil was cooked on cylinder 7 and plug was firing weakly and only sporadically. Nice to learn that my truck has the idiotic plug design with the electrode shield carbon build-up that causes the plugs to break off in the head. But I followed the TSB 08-7-6 to the T (OK, engine WAS a little warm :-) and got them all out. Of course, #7 was not firing and the plug shield had no carbon, so that came right out. But thank god the other 7 did! No one in my area had any nickel anti-seize so I'm waiting for a tube off ebay and will take them out and coat the shields later. Nothing's easy!
#51
#52
That's a great price
$4.62 per quart for SP ?? That's a great price. You won't find it cheaper anywhere.
My local O'Reilly is 5.99 per quart, and dealership is closer to 8.
#53
I would if it were mine.
#56
#58
"Drain intervals across the board with the new fluid will be 150,000 miles for passenger cars and trucks, in normal service," Ved said. Ford says Mercon LV has strong potential for increasing the severe-duty service change intervals, as well, which it will announce at a later date.
Only one additive package, made by Afton Chemical, has been approved for Mercon LV, Ved pointed out. It took some three years to validate the additive package for Ford's factory fill, and only then was it considered for service fill as well. The Afton package includes a detergent-inhibitor package and a shear-stable viscosity index improver package. Depending on the base stock used, treat levels are expected to be in the range of 11 to 14 percent.
To meet the performance demanded by Mercon LV, most products will need to be formulated with Group III oils, Ved added. "Based on Mercon LV's viscosity, shear stability and antioxidancy requirements, use of higher-end Group IIs, Group III and PAOs will be the best scenario." He said there seems to be adequate supply of Group IIIs to meet the volume needs, as the LV market develops; also, there will be less turnover of the fluid, since the transmission fill intervals will be so much longer.
Mercon LV joins Mercon V and Mercon SP as the only current Mercon products for conventionally shifted automatic transmissions. (There is also Mercon C, designed for CVTs).
"The goal with LV was to create a more robust fluid, even beyond that of Mercon V," Ved said. "We aren't yet replacing SP, which is used in our conventionally shifted five-speed and six-speed transmissions, but there is a significant amount of testing ongoing to replace SP with Mercon LV."
Due to viscosity differences, LV is not intended as a substitute for Mercon V. "Newer transmission technologies are being developed with low-viscosity fluid," he added. "It's fill-for-life, and has more stable friction properties, and will maintain the shift feel throughout the fluid's life. It also will maintain its viscosity with less than 5 percent viscosity change over the life of the fluid."
The major additive companies all hope to gain the automakers' factory-fill business, and Laurie Strasser, marketing manager at Afton Chemical in Richmond, Va., said her company was gratified that its package got the nod from Ford. "We're blessed with an excellent research team, who put forth solid technology, considerable persistence and hard work," she said.
The key, as with all emerging technologies, was to provide measurable improvements in multiple areas. "Every OEM is looking to boost fuel economy by optimizing the transfer of power along the complete drivetrain," she said. "Another key demand is for greater friction stability. We've seen this emphasized with General Motors' Dexron VI fluid, with the JASO specification in Japan, and now Ford's Mercon LV. The OEMs want consistent friction performance -- shift feel -- throughout the life of the product, and for the product to have a longer life as well."
#60
I have heard that Shell makes SP for Ford.
http://www.equivashellmsds.com/
Enter Product code - 53174 OR MSDS Number - 401519E in the search box
