Squeaking
IMO, i would personally not spray any kind of dressing, etc. on the belt. find out what the cause is and fix it right the first time. dressing will usually just temporarily quiet the belt, only to return again, sometimes worse than before. mine squeeked like mad a while back, replaced the belt that was caked with residue from some type of lubricant from previous owner, that didn't help, it ended up being the tensioner causing it. good luck!
Other Possibilities for Sqeels?
Hello,
Just want to thank all for their knowledge shared here on this superb forum.
In re: to the squeeling, I have experienced this too. I replaced the belt as it appeared a little dry & I was unsure of it's history. About 8 months later I used a bit of belt dressing (*sparingly*). But a few months ago, I have had to rebuild (repacked) both the idler roller (?) and tensioner bearings. They both appeared to be in need of some attention. The squeel did go away @ that point.
However sometime later now, I have what appears to be a squeel in the area in front of the water pump, but it doesn't appear to be the fan clutch. So i'm thinking the water pump itself? I wondered if I read this somewhere about a front bearing in a water pump???
If anyone stumbles on this I be happy fer some commentary
Thanks again, jm
99 Ranger 3.0
Thanks again, jm
99 Ranger 3.0
jrs1987
1983 - 2012 Ranger & B-Series
04-16-2020 06:57 AM
feigerou
09-04-2008 09:26 PM
Ranger Steve
09-06-2006 06:53 PM
