Can't find plug for oil pan in 2000 Ranger
Well, when I can't find stuff, I go to the source. First I look for the oil pan, which usually on cars and trucks is on the botton(except dry sumps). Anyway, with a lot of cars, the plug is set towards the back of the pan, and usually on an angle. Then you have your bigger engines which stick it right in the middle. But maybe there is a cover over your pan, and maybe its molded to the oil pan. I can't be sure, but I've heard of things like it. So do a S&R mission, and find that plug! Or call the dealer and ask them, for a friend
Originally Posted by vfrocket
ditto Celly140... its on the back side of the oil pan, i usually just crawl under behind the drivers side wheel and it is relitively easy to reach, the real trick is getting your hands on the filter which Ford in their infinate wisdom put just above the starter....
I changed the oil in my '00 XLT Sport 4x4 3.0 yesterday, and to my surprise, under the oil filter is a 'funnel' and tube, to allow the oil escaping from the oil filter flange to be carried away from being 'splattered' all over the block, the starter, the front differential and the front driveshaft!
Good job, Ford!!!
(Daggone. I wish I had thought of that!!!!!!!!!!)
BTW. . . I bought my truck 1 month ago. It has 61,500 miles on it.
"Ford Has a Better Idea."
My 2000 3.0 has the little funnel too. It's a great idea but it is really made a little too wimpy . I also can't believe how hard it is to remove the old filter without spilling oil all over the place. That pesky steering wheel shaft is right in the wrong place . But i'm not complaining, I still love my 3.0!
alnbrgr2014
1983 - 2012 Ranger & B-Series
03-23-2015 09:10 PM
RabidJade
03-30-2010 08:09 PM
