Carb Backfire Problem Finally Fixed!!!
Old 12-18-2004, 07:29 PM
sdkoz's Avatar
sdkoz
sdkoz is offline
Have a 600 cfm Holley 4160 on a 77 F-100 step-side with a 400. I searched and posted here (and other forums) for a fix to my carb backfire problem. Got lots of good ideas and tried several: adjusted the float level and air mixture screws, looked for vacuum leaks, adjusted the vacuum advance, rebuilt the carb, and rejetted - all with no success. Was almost to the point of dumping the Holley for an Edelbrock due to Holley's tendancy to have backfire problems (try searching this forum on "Holley" and "backfire") But, it turned out to be TIMING. I had tried different timing settings from 0 BTDC to 30 BTDC, when I tried ~1 deg. increments. Turns out it backfires at 12 BTDC, but runs like a banchee at 15 deg. BTDC. Finally got my truck back. Thanks for all the help!
djc1978
06-17-2016 06:34 AM
thumbs08
04-16-2012 07:42 AM
77F250CUSTEXP
07-08-2011 11:47 AM
Countrywfo
02-01-2011 06:44 PM
TexasBronco
1978 - 1996 Big Bronco
11-09-2003 05:24 PM
Quick Reply: Carb Backfire Problem Finally Fixed!!!
