1978 - 1996 Big Bronco
Poor Acceleration and Backfiring Resolved
Old Nov 9, 2003 | 11:35 AM
TexasBronco's Avatar
TexasBronco
90 Bronco 5.0L w/ 4WD
I have had a long running problem w/ poor acceleration and backfiring once the engine fully warmed. No missing but engine would practically die under acceleration and usually lightly backfire through the throttle body. I discovered that retarding the timing a few degrees from 10 BTDC to about 6 BTDC helped a lot but did not fully cure. Engine idled fine and cruised at steady speed OK.
I checked every system that I felt could potentially cause this problem w/ no faults found.
No codes are set.
I finally decided to replace the distributor, since the issue appeared to be related to the timing w/ a warm engine. I purchased a used distributor from an 86, 302 mustang on ebay. It looked pretty rough when I got it, but I cleaned it up, new oring and installed.
It appears to be the cure. Engine will now accelerate reasonably w/ timing set at 10 BTDC, and no backfiring.
My speculation is the timing sensing device in the distributor was somehow sending a faulty signal that caused an improper timing response by the ECU.
I've seen similar problems posted on this forum, and hopefully this may be of help to others.
Regards
Old Nov 9, 2003 | 05:24 PM
Black Ford XLT's Avatar
Black Ford XLT
dist
Glad ya found ya problem, i replaced mine with a dist from msd , a billet wow what a difference that made
jasindude1
Nov 3, 2019 11:37 AM
wrooper
Sep 22, 2016 05:45 PM
JeepScrambler
Oct 24, 2014 10:18 AM
TonyGalasso
Feb 18, 2013 02:48 PM
77F250CUSTEXP
Jul 8, 2011 11:47 AM
