p0147 and rough idle when cold
For the last few cold mornings when i start my explorer it will idle fine, then i will hear a click and it sounds like it wants to stall. After a moment, i think i hear the click again and the idle surges a little. Eventually after the engine warms, the explorer will idle fine. This morning while driving to work my CEL light came on. I had the code read and it is P0174. Do these symptoms point to bad oxygen sensors?
Thank you in advance for you help
Thomas
Thomas
i have a 97 explorer with the the sohc and 117k miles. I do remember that around 39k, I had a similar problem except the CEL light never came on. I had the oxygen sensors and gaskets replaced under warranty. Tonight, I cleaned the mass airflowsensor and reset the computer by disconnecting the batter for 5 mins. Will see what happens in the morning. I really appreciate the responses I have received
well, i cleaned the airflow sensor and iac, reset the codes and thought i was golden. The next morning it started up and maintained the idle. However, 2 days later is did the surging from 2k to 500. Looks like I will be changing manifold gaskets. I want to thank everybody again for taking the time to try and help me
Wit-in-MN
12-12-2016 12:29 PM
bluescrew
12-31-2009 09:06 PM
mrbill_sd
03-20-2002 10:53 PM
