Diesel crackle
Old 12-02-2004, 03:51 PM
dlevey's Avatar
dlevey
dlevey is offline
Diesel crackle
This may be a dumb question.. I am a fairly new diesel owner (2001 F-350 63,000 miles). Ive noticed more of a crackle noise under light acceleration or around 1500 rpm. I have added more hp lately also. Should I be concerned? It sounds good at idle and during good acceleration. Mabey I just need to drive someone elses around to see if it is normal. Thanks
Old 12-02-2004, 04:42 PM
mech2161's Avatar
mech2161
mech2161 is offline
Location?temps? possible poor fuel quality and or winter blend. Try a fuel additive.
Old 12-02-2004, 04:54 PM
dlevey's Avatar
dlevey
dlevey is offline
I am in Ga. It has been 30-60 deg outside. I usually use Diesel Clean every other fill up. But from what your saying do I lean tword the side of fuel delivery?
Old 12-02-2004, 07:42 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
Check this out.
I am sure it is what you are hearing. and will give you a few ideas on how to fix it.
https://www.ford-trucks.com/forums/s...d.php?t=304751
Diesel Rod
Old 12-03-2004, 06:45 PM
dlevey's Avatar
dlevey
dlevey is offline
Thanks alot for all the input!!! I did a search befor I posted and couldnt find much info. I just needed to use the right term!! "cackle"
Thanks guys
maxride
02-26-2016 02:51 PM
gacrkr85
1997 - 2003 F150
01-03-2014 05:22 AM
luvemhot
05-11-2011 11:58 PM
tp4pdb
Aerostar
03-26-2009 05:16 PM
carter442
09-13-2008 04:56 PM
Quick Reply: Diesel crackle
