Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-23-2004, 02:40 AM
dieselfish dieselfish is offline
Garage is empty, add now
dieselfish is starting off with a positive reputation.
Question about propane injection and towing
From Quadzilla: "If you decide to install a system, let me know, and I can walk you through the initial "dial in" procedures."
I have driven ford diesel trucks since 1983 and made many modifications on them. I have never used a propane injection yet. Due to my business, I tow RV's very long distances. I have a 4" exhaust, cold air intake system (K&N), Superchip Trimode Tuner and a full gauge system on a 1996 F250 4x4. My mileage is only 12 mpg towing and 15-18 mpg empty (automatic, 3:55 gears). I have access to a complete used Bully Dog system for a 7.3 PS. Would this be a good addition to my towing package?
  #2 (permalink)
Old 11-23-2004, 02:53 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
I don't have any personal experience with a Bully Dog system, but the general concept of propane injection has some common ground. With propane on while towing, you'll find that you've got more power for pulling hills, and you'll get better mpg from the #2 diesel you're burning.
To set up your system, initially get it adjusted to your truck when you're not towing. You'll probably want the propane to start flowing at around 4psi boost. (Ideally, you want the propane to start flowing at 1psi higher than you typically run at freeway speeds.) You'll also want to adjust the amount of flow so you can't make the truck detonate at that setting. Once you've found the correct adjustments for those two parameters, to adjust it for towing, you'd want to set the propane to come on at about 7-10psi boost, or 1-2psi higher than you run on the freeway while towing.
I hope this gets you started. If you have any other questions, post them here, and I'll check back periodically.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
Tags
f250, injection, propane, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
