Daystar Leveling.....I Love it.
#34
Originally Posted by talljeeper
Has anyone with daystars noticed a knocking sound when driving over a bumpy road? Or will this sound go away when they settle in a bit.
<HR>
That’s your upper control arm hitting the coil spring.
<HR>
I'm not sure why Daystar would be any different than the others though. If they all lift the front 2.5", shouldn't the control arm and coil spring be that close together on any leveled truck?
#35
The spindle shouldn't hit the spring, but the way the kit was made at full extension it does. I have the Skyjacker 2.5 spacers and it does the same thing. I assume the squeaks come from the material the spacers are made from. Is that a bad thing? I don't really care my lift is just for looks.
not touching stock extended
http://216.77.188.54/coDataImages/p/...rballjoint.jpg
touching after skyjacker spacer, extended
http://216.77.188.54/coDataImages/p/...4assembled.jpg
#36
#39
Beefford
You should be able to do it as long as you have the proper tools. I created a post some time back about my 'do it yourself' install. It is full of little things the instructions don't tell you. My biggest piece of advice is to make sure you have a really good spring compressor and alot of patience. Follow the instructions and you should be able to complete the job in 3 or 4 hours. Make sure you read my post 'Daystar Install' before you get started, it may make the decision for you.
#40
#41
MRStace84
12-27-2003 12:00 AM
davelaboss
1983 - 2012 Ranger & B-Series
11-17-2003 08:05 PM
