what does ecg mean?
Old 11-06-2004, 08:32 PM
JByrd1173's Avatar
JByrd1173
JByrd1173 is offline
what does ecg mean?
what is ecg/ezg/abc/lol/mean?
Old 11-07-2004, 04:50 AM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
The ecg# of importance is on the rocker arms. The ecg is the high ratio rocker at 1:54 ratio instead of the 1:43 ratio.
ecz USUALLY not always means 312
Two of the engines I bought were of the ecz code one was an "A" block and one was a "C" block. The ecz-6015-c block is a 312 I already checked. I dont have the pan off the ecz-6015-a engine yet,but I think it will be a 292. The third engine is a EBU 1954 car 239.
Kevin Bigwin
Old 11-08-2004, 03:38 PM
286merc's Avatar
286merc
286merc is offline
ECG is a date code in Fords old system. In this case it is 1953 that the design drawing was made, production is often the following year. The code may carry over for several years if no changes were made. It eventually became so confusing that the current code was started in 59. IE: a B9AE block is 1959, a C9AE is 69, a D9AE is 79, etc.
Old 11-09-2004, 02:07 PM
55Bubba's Avatar
55Bubba
55Bubba is offline
ECG is actually (according to my Y block Book) one of the incarnations of our venerable Y blocks. It is a 272 version with a little higher compression ratio and putting out an advertised 172 hp.
EZG I believe is another Y block version maybe even a 312
ABC I don't know
LOL....laughing out loud?
Hope this helps
Bubba
Old 11-09-2004, 05:06 PM
286merc's Avatar
286merc
286merc is offline
ECG is actually (according to my Y block Book) one of the incarnations of our venerable Y blocks. It is a 272 version with a little higher compression ratio and putting out an.....
That is only partially correct. As I said above ECG is basically a date code. To be meaningfull it has to be followed by a group #.
ECG just by itself doesnt mean squat otherwise as it covers a wide range of parts.
As an example ECG-6015 signifies an engine block since Ford uses 6015 as the group # for all engine blocks.
You got it yet?
Old 11-10-2004, 07:09 AM
55Bubba's Avatar
55Bubba
55Bubba is offline
I think the designation ECG is important and I believe it was later than 1953 since the first 272's came in late 55 to be larger than the Cheby V8 initial offering 265.
As stated my info came from a book showing history of the Y block
I'll be reading more and posting less I guess
Bubba
Old 11-10-2004, 09:43 PM
286merc's Avatar
286merc
286merc is offline
Sounds like a plan.
Guess you didnt read my statement that the ECG was applied at the time of the initial engineering drawing. Those books of yours dont tell you that a 55 production engine wasnt started in the design cycle in 55. They didnt have computers back then either; 2 years was a fairly typical cycle.
Old 01-01-2007, 11:44 PM
f700's Avatar
f700
f700 is offline
heads
hi all just reading your threads about heads will a 272 head fit a 292 ?
Old 01-02-2007, 03:07 AM
pcmenten's Avatar
pcmenten
pcmenten is offline
Yeah, although you'll want to start a new thread to discuss interchange issues. The ports on "272" heads are usually smaller than the ports on 292's, although in 1957 I think the 272's had the ECZ heads and big port intakes.
Old 01-02-2007, 05:35 AM
f700's Avatar
f700
f700 is offline
heads
thanks y i ask is i just crack a head CITE on my 292 i can get sum i think they are 272 heads bore =3.62 casting number from over the phone are
heads = ECG-S69T
= ECG-6015-A
all of the one head he said to me that it was EOG-6015-A
Old 01-03-2007, 03:57 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Gentlemen,
ECG is a PN Prefix used to identify a particular engine. All FORD engines (even early FE) in the fifties used this method until, as mentioned, the system was changed to the more familiar system in 1959.
http://www.ford-y-block.com/cylinderheadchart.htm
Harrier
1802
12-30-2023 06:32 AM
Bill W
04-21-2017 05:48 PM
fisherman_chuck
04-19-2016 10:14 PM
1960fordf350
07-11-2015 08:47 AM
flipklos
05-16-2009 09:36 PM
Quick Reply: what does ecg mean?
