Strange thing happened... answer this one.
Originally Posted by greenroses
Someone else try it, please. When you're on the freeway pump the gas once to the floor quickly and let up. What happens? I'd like to know if this is a common problem or if it's unique to my rig.
Originally Posted by timhood
I think you got off track. To quote the original question:
"I put the pedal to the floor. Right away I changed my mind and let up right away, but the rpm's flew up to about 4000 rpm's and stayed there for about 4 or 5 seconds before coming down to normal. Funny thing was that the truck didn't seem to change gears or react in any other way except to rev up the engine. No power was transfered to the driveline."
We're not talking about the accelleration lag, we're talking about the engine revving for several seconds with no power transfer. You simply cannot blame that on drive-by-wire because power transfer happens in the transmission.
As for accelleration lag, it's possible with or without drive-by-wire. With drive-by-wire Ford could have chosen to put a slight delay or require a minimum throttle input in order to give the drivetrain the illusion of a smoother start. However, do some research and you'll find many complaints logged in auto reviews for transmission lag on many vehicles with conventional accelleration. So, just because there's a lag in the F-150 doesn't mean that only drive-by-wire systems have it. (It also doesn't mean that the throttle programming isn't the only cause of the lag).<!-- / message -->
Originally Posted by asinatra
Dont worry about it, it happens, your getting worried over nothing. Most the guys that post on these f150 forums are just regurgitators and just go off of what others have said.
Dont worry about it, it happens,...When you need to get out of the way and can't because you truck doesn't respond like it should that is something to worry about, that's dangerous and an accident waiting to happen. When you hit the gas you expect to go, that's the whole point isn't it? There have been many close calls and accidents logged on this forum and others because of this problem, whether it's caused by the torque converter, throttle by wire or a combo of both.
i think that a lot of people have their own opinion of what might be causing a particular problem. It's just like the vibration/steering wheel nibble/bed shake, there are so many different opinions on causes/fixes that its mind boggling. Who's right/who's wrong, nobody knows not even ford. I don't think it is regurgitating sombody elses thoughts and opinions it is that many people have similar opinions on similar problems.
I realize I have the older style truck, but mine had these identical symptoms when I bought it a month ago. The more I drove it the more I disliked it. Took it back to the dealer for the shifting/ hesitation problem and they replaced the torque converter under warranty. Now it drives great! No hesitation in the throttle whatsoever.
TPS Reports
Originally Posted by mkoser
From now on we are using the NEW cover sheet on the TPS reports, did you get the memo? I'll see that you get a copy of the memo.
Everyone go out and rent Office Space and you'll get it... or maybe not...
