6.9 help need info
6.9 help need info
I need some info here, i'm looking at doing a engine swap, putting a 6.9L in my F-350 which curently has a 5.8 W/C6 I was told the 6.9 C-6 has a different bell housing, so can i just swap the housing on mine? does any one know what else need to be changed other than th obvious, radiator, fuel system, ?? Thanks for any help you can give. DW
Well, first, the bell housing on a C6 is integral with the rest of the case. so you will need the whole trans. Next, the rad support is different, heavier, so you will need that. The 6.9 is considerably heavier, so the springs will need replaced as well to hold up to the additional weight. A complete parts truck would be your best way to go to get all of this.
I haven't done the conversion, but in my experience the bells are not the same, the diesel has it's own bell, the closest is the 460 bell, the small block bells are too small.
https://www.ford-trucks.com/forums/s...d.php?t=275511
https://www.ford-trucks.com/forums/s...d.php?t=266721
