6.9 help need info
Old 11-01-2004, 04:53 PM
DW2455's Avatar
DW2455
DW2455 is offline
6.9 help need info
I need some info here, i'm looking at doing a engine swap, putting a 6.9L in my F-350 which curently has a 5.8 W/C6 I was told the 6.9 C-6 has a different bell housing, so can i just swap the housing on mine? does any one know what else need to be changed other than th obvious, radiator, fuel system, ?? Thanks for any help you can give. DW
Old 11-01-2004, 05:30 PM
fellro86's Avatar
fellro86
fellro86 is offline
Well, first, the bell housing on a C6 is integral with the rest of the case. so you will need the whole trans. Next, the rad support is different, heavier, so you will need that. The 6.9 is considerably heavier, so the springs will need replaced as well to hold up to the additional weight. A complete parts truck would be your best way to go to get all of this.
Old 11-01-2004, 05:50 PM
madmaxxcustoms's Avatar
madmaxxcustoms
madmaxxcustoms is offline
the bell housing is built w/trans on C6 but trans are the same what is needed is the
plate that goe's between trans and motor you also need mounts,rad,wire harness
for glow plugs.core supt.a parts truck is the best I just did a 460 to 6.9 swap
Old 11-01-2004, 07:51 PM
DW2455's Avatar
DW2455
DW2455 is offline
Well that what i got was a whole parts truck, as far as the tranny, the donor truck is a man. trans, so are the bell housing paterns diferent between the 5.8 and the 6.9 C6's??
Thanx DW
Old 11-01-2004, 08:01 PM
madmaxxcustoms
no the bolt paterns are the same
Old 11-01-2004, 08:18 PM
DW2455's Avatar
DW2455
DW2455 is offline
so i should be able to pull both trucks side by side swap the motors and ness. stuff and kepp the original tranys in ther trucks? That would be great. DW
Old 11-01-2004, 09:59 PM
fellro86's Avatar
fellro86
fellro86 is offline
I haven't done the conversion, but in my experience the bells are not the same, the diesel has it's own bell, the closest is the 460 bell, the small block bells are too small.
https://www.ford-trucks.com/forums/s...d.php?t=275511
https://www.ford-trucks.com/forums/s...d.php?t=266721
