Intermittent Starting
When I turn the ignition switch of my 1994 Explorer the electric fuel pump begins working just before I start the engine. This must be the design, because every time I hear the fuel pump, the engine fires right up. Other times I turn the switch and there is no sound indicating the fuel pump is working. When this happens, the truck will not start, though the engine turns. I find that if I remove the key or jiggle it, I can sometimes get it to start. Based on that, I had the ignition switch replaced but the problem persists.
It's been to the shop 3 times and they can't duplicate the problem. The fuel pump pressure checks out and there are no problems codes. What else could it be?
Help! I'm tired of getting stranded.
F150-4-Life
24
06-06-2010 09:15 PM
Dave88F250
11-01-2005 07:34 PM
Chickenmantoo
Bronco II
05-06-2002 09:55 PM
