E350 Starting Problems
Old Feb 16, 2008 | 06:53 PM
Auztone's Avatar
Auztone
I have a 1995 E350 with a 460CI engine. My problem is that when I try to start the engine and turn the key on the column, sometimes nothing happens as in no cranking of the engine. Almost as if the battery was completely dead. I can hear the fuel pump and other things click on but no motor turn over. If I turn the ignition switch on and off a couple of times it will eventually start cranking and start. I had the starter checked out and ignition switch replaced but still have the problem intermittently. Can this be a problem with the ignition key cylinder? Any help is much appreciated.
Thanks
Auztone
Old Feb 16, 2008 | 07:38 PM
jonesg's Avatar
jonesg
Another thing to check is the tranny shifter.
Old Feb 17, 2008 | 07:10 PM
Auztone's Avatar
Auztone
Where is the sensor for the tranny shifter? Is it on the column or ??. Thanks!
Old Feb 20, 2008 | 03:08 PM
jonesg's Avatar
jonesg
I don't know where its located. Its gotta be in the Haynes.
Old Feb 22, 2008 | 04:29 PM
kynnhoj's Avatar
kynnhoj
Older Fords (I don't know if yours is included) had a problem with the start wire (12 gauge?) corroding just off of the starter solenoid. It will appear ok but coroded under the insulation.
Another thing to consider is if your van has an additional solenoid near the starting battery, my '98 has one and it went bad.
Good luck, John
Old Aug 12, 2008 | 12:20 PM
Auztone's Avatar
Auztone
I have now checked the start wire and key cylinder. I'm now suspect the tranny shifter not sensing that it is in the park position. I can't find the location of this sensor. Is it in the tranny itself or ??? I can't seem to find any information in the Chilton's book that I have. Any help is greatly appreciated. Thanks
Old Aug 12, 2008 | 01:11 PM
kynnhoj's Avatar
kynnhoj
Located on the drivers side of the tranny. Possibly out of adjustment. It has slots to adjust. (rotates).
Also, wire connecrtions can appear clean but be corroded.......
john
Old Aug 13, 2008 | 11:51 PM
neil 95 e350's Avatar
neil 95 e350
the poor man's quick way to test the neutral safety switch is to put the key in the ignition, turn it to crank and wiggle the shifter. if it all of a sudden it cranks and you wiggle it some more and it stops, the try adjusting the NSS . if that doesn't work replace it.
remember, YMMV
neil in san marcos
Old Aug 14, 2008 | 08:50 AM
subford's Avatar
subford
Check for loose screws at the bottom of the steering column at the shift cable bracket that holds the transmission shift cable.
This happens a lot, make sure gear pointer is pointing at the correct place (gear) and tighten the two screws.
Old Aug 14, 2008 | 02:44 PM
Auztone's Avatar
Auztone
All sound like good ideas. I will try them out this weekend. Thanks!
Cheers!
Old Aug 14, 2008 | 05:50 PM
forddriverdad's Avatar
forddriverdad
My 93 E350 with 460 in it just got a new starter to solve problem like that , I really had a problem after running it didnt want to start back up , new starter spins motor so much faster.
Virg
Jul 26, 2015 12:56 AM
Toplait
Jun 17, 2015 09:03 PM
michael101
Escape & Escape Hybrid
May 16, 2010 03:56 PM
Auztone
Aug 2, 2009 09:04 PM
Auztone
17
Oct 29, 2007 08:13 AM
