Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 10-16-2004, 08:32 PM
twinanchor twinanchor is offline
Garage is empty, add now
twinanchor is starting off with a positive reputation.
rear bearing check and steering adjustment
Looking for someone that knows what to look for when checking rear bearings on big bronco or 1/2 ton . how much lateral movement of axle is allowed? up and down movement? etc. also what is the quick way of adjusting power steering box? thanks
  #2 (permalink)
Old 10-16-2004, 09:29 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
For the bearings there should be mimal to no movement and if there was this would indicate wear problems, as for the steering i wouldn't be able to tell you but if you go and check in the forum that your truck is located in you should be able to get somehelp on that one.
__________________
Cody, Calgary
AB
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #3 (permalink)
Old 10-16-2004, 09:40 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Tech questions are best placed in the tech forums.,
This thread will be moved to the Drivetrain forum
Tags
adjustment, ford, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
