Casting numbers
If you look closely is a reverse "105" used mostly on the 361/391 FT series. The heads are 68 390 heads Mercury 4V or high compression 2V with 67.1-70.1 chamber volume. I think the "105" blocks were cast at MCC (michigan casting center) vs the DIF (dearborn iron foundry). As wisely instructed check the bore and stroke of the engine. The 361/391 both have a bore of 4.05 std 390 and the crank strokes are 361 at a 3.50 stroke and the 391 a 3.79 both used a forged steel crank unlike the std FE nodular iron. G.
105 Mcc
Paul G.
Oh BTW from what I understand as the FE was being replaced by the 429/460 series MCC was using the same castings for all FE blocks except the 428 and 427 which stayed at DIF until they closed. The "105" blocks were cast and then machined for the application needed be it a FT series or a 360 or 390. Generic yes but cost effective. This might be where the confusion is between the different blocks. Hope this clears things up a bit. G.
StockMan
01-08-2013 02:19 PM
Daltonsheets1995
06-01-2012 01:17 PM
jacob_9249
07-26-2008 08:04 AM
Ratsmoker
12-12-2001 04:52 PM
