rebuilding injectors question on 7.3 IDI
Is it possible to rebuild injectors on a 7.3 IDI motor yourself? I have white/blue smoke and am trying to isolate problems and correct them. There is also a rod like knock so I think at least 1 injector is stuck. Can I rebuild them myself? What is the best way to find out which is the bad one? Are there any kits and instructions on how to do it out there? Thanks for any help.
Unless you have an injector shop in your home shop then you probably cant do it. YOu can go to http://www.shopdiesel.com and order a new set for 200.00. I replaced my injectors and had to replace the fuel lines to get it to run good. It was puffing white smoke because of air in the lines and it had slow throttle response.
Athanasius
03-22-2014 02:27 PM
Bane270
13
03-11-2014 08:39 AM
Markiv
03-10-2014 10:55 PM
