Offroad & 4x4
SSR radial or Baja Claw
Old 09-21-2004, 08:13 PM
snipercole's Avatar
snipercole
snipercole is offline
I am looking at new tires for my F250 powerstroke. I posted a while back asking about tires. I have found two that I like. They are the Super Swamper Radial SSR 37x12.5/16.5 10 Ply and the Mickey Thompson Baja Claw Bias Ply 37x13.5/16.5. I was wondering which one would be the best tire for mainly highway driving. I think the SSR would last longest, but the Claw would ride quieter and be easier to balance. My truck is geared for 39.5's right now. Would a 37 be too small to work with these gears or do i need to stay with at least a 38.
Thanks
Gene Cole III
Old 09-21-2004, 08:30 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
those mickey's are pretty hard rubber. i believe the MT's would last longer
-cutts-
Old 09-21-2004, 09:43 PM
bremen242's Avatar
bremen242
bremen242 is offline
-cutts-
one of the local shops had a set, and he said he got about 10-12k out of them.. not good, at least imho
Old 09-21-2004, 09:45 PM
ivanribic's Avatar
ivanribic
ivanribic is offline
Personally I like the Mickey's but they are not by any means a quiet ride. If you're doing a lot of highway driving get the SSR's. Your ear drums will thank you. Mickey's aren't as loud as a Turdbird but they do hum big time on pavement. I think the SSR will outlast the MT's based on what I've seen for wear. One of the Cheby guys who is always at the ORV park has them and they seem to be burning up pretty quick. They do look hella cool though.
Do you know what gears you currently have in the axles now?
Old 09-21-2004, 10:16 PM
02superstroker's Avatar
02superstroker
02superstroker is offline
I run the SSR's they are okay, but certainly not a great highway tire... what swamper is? They won't wear great.. natural for a swamper. Mine have worn pretty good considering.. but I also have one who's belts are seperating... Im not very happy about that. Overall a good tire... but I won't buy them again. Have you looked more into the parnelli jones dirt grips, or perhaps even the new toyo mud terrains? They arn't quite so aggressive...
Old 09-21-2004, 10:57 PM
mustange70's Avatar
mustange70
mustange70 is offline
The radial baja claw will last longer then the bias ply but i can't remember if they come in that size. And although there will be a difference at highway speed and rpm, it shouldn't be all that big of a differnece. It would be similar to a stock truck with 4.10's and a stock truck with 3.50s. Another good tire that you might want to check a set of goodyear MTR's
Old 09-22-2004, 08:39 AM
snipercole's Avatar
snipercole
I am not sure what the gears are now. I abought the truck used and the dealer told me that the guy who traded it in has re-geared it for the tires.
Old 09-22-2004, 11:12 AM
Ronin007's Avatar
Ronin007
Ronin007 is offline
I use to run a set of Baja Claw radials on my SD and they were a good tire, but wear was terrible. I think I got about 20,000 miles out of them and they were chopped up with regular rotation. Being a directional tire you could only rotate front to back so it limits you in trying to even out your tread wear.
If you are going to run mainly highway have you considered an AT tire like the Trxus? I hear they wear well. Personally I am not crazy about the looks, but they might suit your needs. I am sure that there are a ton of other tires too. May Nitto, Toyo, BFG, etc.
Old 09-22-2004, 11:21 AM
fishmanndotcom
geex i thought the claws were supposed to last longer on the road than that! i might be thinkning of the baja belted tires maybe, i dunno. thanx for the heads up
i am seriously condering goodyears new blank tires that you cut and groove to your liking! that would be sweet to have a custom tire made in your garage
-cutts-
Old 09-22-2004, 11:48 AM
Ronin007's Avatar
Ronin007
Ronin007 is offline
cutts - you probably were thinking of the Baja Belted as I hear those wear well. Those might be a good option for snipercole. I have been considering trying the MTX tires as my DD tires on the SD, but hear mixed review on them. Got my snows on early since I took the bland and wavy Claws off. Guess I will wait until next year to make up my mind.
Prozon
Offroad & 4x4
60
04-02-2009 11:49 PM
2112
09-21-2004 10:18 AM
FordMan05
09-04-2003 10:27 PM
bugsy
04-25-2003 08:32 AM
Quick Reply: SSR radial or Baja Claw
