Rebuilding a 1990 Ford 429 engine
Originally Posted by stevef100s
Hmmmm. Tough to say, since you have the only one that was ever made. lol. Hasn't been any other factory built Ford 429 made since the early 70's. Or was it the late 60's?
Oh, and Manuel, go buy a hanes or chilton. They will have all of that information in them.
Yes, it a truck engine, from a 1990 F-700, I was rebuilding the motor due to problems with a piston rod and after rectifying the block and cylinder heads I really can't find the torque specifications required to assemble the motor again.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Thanks<o></o>
mjms<o></o>
<o></o>
Thanks<o></o>
mjms<o></o>
sorry for the error
Yes, it a truck engine, from a 1990 F-700, I was rebuilding the motor due to problems with a piston rod and after rectifying the block and cylinder heads I can't find the torque specifications to put back the motor together.
thanks
mjms
<o></o>
thanks
mjms
<o></o>
Incase you havent gotten to the ford dealer yet.....
http://homepage.mac.com/the_webers_inc/429s.pdf
Towards the bottom are the torq specs. Again this is for a 1995 so it should be the same.
Hope this helps,
T. J.
Hope this helps,
T. J.
blueracer69
01-07-2012 08:29 AM
rotaxtwin
07-08-2007 11:53 AM
boss429_1969
08-23-2006 11:24 PM
firedog4689
12-21-2004 07:45 PM
