1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Power Door Lock Problem on 2000 F250
Old 09-02-2004, 09:41 PM
2000F250SD's Avatar
2000F250SD
2000F250SD is offline
I am having a door lock problem on the passenger side door of my truck. It won't work off the keypad and it wont work off the controller on the door. It sounds like it might be a solenoid. Anybody ever encounter this? Also I am getting an intermittent door ajar signal which is probably related.
Old 09-03-2004, 04:48 AM
V10man's Avatar
V10man
V10man is offline
I'd spray the crap out of the lock with WD40 and work the latch well before spending cash.
Old 09-03-2004, 01:32 PM
02superstroker's Avatar
02superstroker
02superstroker is offline
It is the lock actuator- IF.. when you press unlock does it "try" to unlock it but it won't do it all the way? That problem seems to be common. If its not doing anything at all when you press unlock then good luck.
Old 09-03-2004, 01:36 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
My 2000 is doing the same exact thing, was told it's the actuators. Haven't taken it in yet though, I'm sure the dealer will want it for at least a day.
Old 09-04-2004, 02:32 PM
FuddV10's Avatar
FuddV10
FuddV10 is offline
Im having the same problem but sometimes it will work.
Old 09-04-2004, 03:58 PM
2000F250SD's Avatar
2000F250SD
Yes when you push the release it tries to open but doesn't quite go up or down enough.
Old 09-04-2004, 06:11 PM
oddjobs2do's Avatar
oddjobs2do
oddjobs2do is offline
Defective door locks it seems
My 2000 f350 i replaced 3 of 4 door lock actuators. They would work sometimes and not others. They are poorly made from what i was told by ford. Mine went bad about 100k. The front was hard to remove. There is a tab in there that you gotta press but it gets pressed and pushed at the same time it is about 1/2 inch by about 1 1/2 inches long. Then i found out it slips off sometimes once you put the new one in so it stops working. But I just have to click in place. I finally tye wrapped it to the door frame so it wouldn't move. The door slaming seems to make it come loose. Maybe I broke something putting it in. I fought it on instalation then figured it out. It was easy once i could see in the door with a mirror and flashlight. Hope I remember when they go bad again...
Regards,
Doug
Old 09-19-2004, 03:25 AM
gsuski's Avatar
gsuski
gsuski is offline
Post Replaced my original actuators with OEM'd
My 2001 F-250 SD door lock actuators got so bad I went to using a key! I bought a pair of OEM actuators from:
http://www.commandoalarms.com/itm30005.htm and mounted them under the latch inside the door using screws supplied where the door starts to round up.
They fit nicely in this position but it does require forming a stiff piece of 1/8" push-pull wire with 90 degree bends to the hole in the latch where the old actuator arm was located. It took me a few hours of time but when I was done the lock actuators worked flawlessly using the existing 2 wires that went to the old actuators. Wire plug needed to be removed and end conneted to the new actuators that were installed. Two holes had to be drilled in the inside door metal to mount with screws supplied. stiff wire length was about 8" for each door. Be careful to route wires so the window does not lower onto them. position use tie wrop or tap to be safe.
The reason I went the OEM route was because of all the post on lock actuators in FTE. Not a job for the faint of heart but about the same difficulty as changing spark plugs on a 2001 F-250 SD 5.4 ltr. Hey it was almost fun again!
Old 09-19-2004, 09:18 AM
valvestud's Avatar
valvestud
valvestud is offline
This is a well documented problem and has been fixed with a new actuator design. I bought mine from and online dealer. All four were replaced (Excursion), and it takes a couple of hours. Do a search in the Excursion area and you find one or more instruction posts.
Joe
Old 09-19-2004, 09:46 AM
oddjobs2do's Avatar
oddjobs2do
When did they change the door locks....I replaced mine in 2003 but imagine the othe ones were originals? JUst wondering if i have a bad set of new ones still.,
Doug
Old 09-19-2004, 12:30 PM
valvestud's Avatar
valvestud
Doug
Don't know when they changed exactly, but here are the curretn part numbers (assuming they didn't change again):
Left, 3L3Z25218A43-AA
Right, 3L3Z25218A42-AA
Joe
Old 09-20-2004, 03:21 PM
mmmPowerStroke's Avatar
mmmPowerStroke
mmmPowerStroke is offline
Just bought my truck and both of the actuators make noise when you press the lock unlock button but of course don't do anything. I saw on fpn.com that the actuators are $41 through them kind of exspensive but well worth it.
Old 12-06-2004, 11:43 PM
pcjack's Avatar
pcjack
pcjack is offline
Hi all, Acutators are a problem on the Excursions and heavy duty F's as well. I replaced the actuators on both my Excursions with the new updated versions. No problem since.
Lotsa luck to all..........
Old 01-17-2013, 01:52 PM
mewesguitars's Avatar
mewesguitars
mewesguitars is offline
I have sluggish door locks when I use the door switch. If I have power door locks do I have keyless entry as I didn't get a key FOB when I bought the truck. I bought a FOB but haing problems getting it programed on my 2000 F250.
Old 01-17-2013, 05:03 PM
Poolguy601's Avatar
Poolguy601
Poolguy601 is offline
If you have the time this is the fix.
https://www.ford-trucks.com/forums/9...-pictures.html
JRD761
6.7L Power Stroke Diesel
09-26-2016 08:57 PM
Mr f250
02-01-2016 10:47 AM
Roc53ky
08-08-2015 06:29 PM
noplugs4me
06-20-2015 04:47 PM
Quick Reply: Power Door Lock Problem on 2000 F250
