ABS Light On After Changing Front Hub
I replaced my left front wheel hub this afternoon. Half way through I started the car to turn the wheel in the other direction to make getting to the bolts easier. I did this before plugging in the new ABS sensor cable that comes with the new hub. I finished the work, everything is put back as it should, and the cable is in place. However, now I can't get the ABS light to go out, I even reconnected the old one just to see if maybe the new was bad, no luck. Does anyone have any ideas??????
Thanks,
Tom
Thanks,
Tom
54Guy
02-10-2008 08:22 AM
