Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-29-2004, 04:41 PM
RealMenPowerstroke! RealMenPowerstroke! is offline
Garage is empty, add now
RealMenPowerstroke! is starting off with a positive reputation.
Question Propane Injection?
Alright ya'll, so I keep scratching my head about this and I can't seem to come to a conclusion one way or another. For the most part we all know sales people are useless so I need some info. Course any help would be greatly appreciated. So basically just tell me if I'm right or way off the mark on this. Since propane injection lowers the engine temperature almost 200 degrees. Would that not help prolong the life of our beloved "Stokes?" If that is the case. Then why is it that no one told me this sooner. I mean I could be getting a good deal amount more power AND prolonging engine life?? TY "Cor"
  #2 (permalink)
Old 07-29-2004, 07:19 PM
kw5413's Avatar
kw5413 kw5413 is offline
Fortune Favors The Brave
2010 Lincoln MKT
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
"For the most part we all know sales people are useless"
Hey! I resemble that remark!
Senseless...maybe...but I am NOT useless. I've been in sales for over 30 years.
I can do and have knowledge of many things.
If you use propane you could also have a built in BBQ in the truck bed...2 for the price of one with a little modification.
See?!
__________________
"A gun is like a parachute. If you need one, and don't have one, you'll probably never need one again."
  #3 (permalink)
Old 07-29-2004, 07:44 PM
F-350 BBQ Grilling!
That is an awesome answer. Plus, you actually have a very good point. I mean you have a built in tailgate party and the tank is hidden anyhow.
  #4 (permalink)
Old 07-29-2004, 07:51 PM
bighoss550's Avatar
bighoss550 bighoss550 is offline
bighoss550 is starting off with a positive reputation.
Quote:
i have never been impressed with propane systems. its not much sense to me to buy tank after tank of gas when a cheap water injection system makes as much or more power, and all u gotta do is pull up to a hose and if u want even more power, just dump in a bit o methanol.....wooo hooo
and water will drop em 300+ deg, and steam clean ur engine insides for free
__________________
03 F550 xlt 4x4 crew cab 6.0t/s
eclipse conversion,
summit "k&n"
exhaust
ZOODAD mod
water/meth injection,
predator
no mo egr
just try to keep up....
  #5 (permalink)
Old 07-29-2004, 08:00 PM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
WELCOME to FTE pleae read the Guidelines and any special instruction at the top of each fourm you vist..............the enjoy
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #6 (permalink)
Old 07-29-2004, 08:09 PM
Water-Eisel
So I'm from Missouri. To my knowledge I've never seen anyone use a water system. First off, is it something you make, or is there actually manufacturers you can by a kit from. Also, I mean since it's water and all is there any side-effects? ty "Cor"
  #7 (permalink)
Old 07-29-2004, 08:48 PM
SBV45's Avatar
SBV45 SBV45 is offline
2009 Ford Explorer
SBV45 is starting off with a positive reputation.
They ain't worth a hoot for BBQ either. That's yuppie stuff. Now if you could do mesquite injection or charcoal.......
__________________
2009 Explorer Eddie Bauer 4.0 V6 4X4.
Previous:
2005 Nissan Xterra 4X4
2003 Ford F250 6.0 Powerstroke 4X4
1986 Ford Bronco 4X4
  #8 (permalink)
Old 07-29-2004, 09:05 PM
powershotone powershotone is offline
powershotone is starting off with a positive reputation.
Propane fumigation for diesel engines has been around for years. It is just been within the last few years that the power has been able to be harnessed so that the benefits , such as cleaner oil, increased fuel economy, lower EGT's and of course the power gains can be utilized by more than just racers and sled pullers. It will not lower EGT's 200 degrees, but it will lower them by 50-100 degrees. You will not run your engine as hard, to make the same amount of power, so yes, I guess you could say that would contribute to engine longevity. If you run a hill at 3/4 throttle towing as opposed to pedal down Check out the dyno sheets in my profile ( I finally found them!!! thanks John!!) I havent seen a dyno report from anyone with water injection as of yet to compare.
Water injection does lower temperatures, It has been used for many years in pulling tractors, for quick relief of the excessive temperatures. Methanol, (also not cheap) needs to be added for power gains. How much methanol used safely is still up in the air. Although I guess the windshield washer solvent is fairly harmless. ( And I thought putting propane into my engine was strange. ) The long term effects of water injection on daily driver diesels has also yet to be determined.
I wondered how much water it uses? I know you can't inject it until higher pressures, like 15 or 20 psi, but how much water would you go through on a long grade for example?
  #9 (permalink)
Old 07-29-2004, 09:37 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Woah Nilly...
Nice dyno chart
Can't wait for some studs and a tranny rebuild to load up on some of THAT
  #10 (permalink)
Old 07-29-2004, 11:27 PM
6.0 "God" hehe
Alright so WOW, that dyno chart is just simply exciting. So what else did you do? Have you scraped your ToqueShift yet?
  #11 (permalink)
Old 07-30-2004, 12:18 AM
Choctaw Bob's Avatar
Choctaw Bob Choctaw Bob is offline
Choctaw Bob is starting off with a positive reputation.
The experts say that the torqshift can handle 1200 Ft Lbs in an empty truck. This means this trans can handle about anything this engine can dish out until you start using bigger injectorsm cam timing, and so on,
__________________
03 6.0 SC Short bed 2WD Auto
Preditor, Gages, K & N FIPK
  #12 (permalink)
Old 08-30-2004, 10:02 PM
hardcase hardcase is offline
hardcase is starting off with a positive reputation.
propane injection plans
I guys I have 84 f250 6.9 andnI need to know if any of yous have some plans for building your own propane injection. Any help would be great.
edited by Tim L
  #13 (permalink)
Old 08-31-2004, 06:49 AM
IB Tim's Avatar
Site Administrator
1989 Swift DB4
Quote:
Welcome to the site Please read the Guidelines.
__________________
Administrator
  #14 (permalink)
Old 08-31-2004, 08:44 AM
bighoss550's Avatar
havent u ever been to a tractor pull????? and ur from missouri???? all the big boys run water. every one of em. ull never see propane on a track. its too unpredictable. anything flammable in a bottle with pressure is a bomb in an accident. no thanks. and a 50/50 mix in the water sys puts just as much power in as a propane system.
mine is home made and if u would like help other than the water methanol injection thread, email or pm me
__________________
eclipse conversion,
summit "k&n"
exhaust
ZOODAD mod
predator
no mo egr
  #15 (permalink)
Old 08-31-2004, 09:52 AM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
Of course propane will help keep the oil much cleaner though. I'm not sure is methanol has the same effect. This seems like a good choice for both power and longevity, especially on an engine with EGR.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
Tags
460, alcohol, build, diesel, effects, injection, international, long, plans, propane, results, term, time, tractor, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
