Horn Problems on a '98 Ford Explorer XLT
Old 10-08-2002, 04:09 PM
California Gas's Avatar
California Gas
California Gas is offline
Hope someone can help!
I recently went on a vacation for 3 weeks and my Explorer was not used....before I left for vacation my horn was loud and very rich....since I have come back it only emits a whimper and is very weak.
I have 2 questions, where is the horn on a '98 Ford Explorer XLT? and does anyone know whats wrong, or have any idea how to fix it?
Thanks in advance!
Old 10-08-2002, 05:16 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
I assume you have cruise control?
If so,Ford runs the horn through a relay under the dash.(at least That where they used to put it)
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old 10-08-2002, 09:14 PM
CobraXP's Avatar
CobraXP
CobraXP is offline
The horn is located under the battery. You access it from pulling down the front bottom part of the fenderwell from underneath. Your horn is actually 2 horns. They are notorious for grounding themselves out. Yours may only have one of the horns out.
When you feel in there, you will feel the power wire to one, and a jumper running to the second. My guess is the jumper has either broke or come off. If the horn grounds itself out, you will lose both the horn and your cruise. They are run through the same circuit in the main Distribution Block under the hood next to the back of the passenger side fenderwell.
Hope this helps...
Old 10-11-2002, 05:50 PM
California Gas
Thanks for the info! I shall investigate this weekend!
Old 10-11-2002, 07:42 PM
topo4u2's Avatar
topo4u2
topo4u2 is offline
Sharps
10-25-2016 01:09 PM
zed326
10-19-2014 12:44 PM
gangstakr
02-03-2014 01:29 PM
F350moneypit
19
02-04-2013 01:46 AM
hodsoway
02-03-2005 04:17 AM
Quick Reply: Horn Problems on a '98 Ford Explorer XLT
