Fuel Additives?
Fuel Additives?
It's a bad idea. People use it as a cleaner because it's high detergent. I read somewhere that it really is'nt very high detergent and I can't remember why but you should just use an actual fuel additive if you are going to use anything. I used atf in my big rig years ago and nothing happened. I also don't know that it did any good.
For a powerstroke I wouldn't use anything unless I was having a problem. The owners manual says not to I think because of all the sensers and stuff.
Fuel Additives
Hey there,
I would like to suggest that you give XFT Xtreme Fuel Treatment a try. It is guaranteed for to effect your vehicle's warrant. The are lots of benefits for your vehicle such as: better gas mileage, less emissions, increased horsepower and performance just to name a few.
check it out your self.
Works With Gas and Diesel
Hey there,
I been using XFT For 4 months with good results. I also have some documents if your still interested.
I have a old 99--and started using a additive when the fuel changed [sulfur]--Have used Standyne==but can not find at a good prise . Have been using POWER SERVICE //PS -DIESEL KLEEN -silver jug --does not get very cold ,so no need for white jug. Best place for me it buy is WalMart..
Results of my request for data from Opti-Lube - TDIClub Forums
