Signal-Stat 900
on
My Signal-Stat 900 SignalFlare has 11 wires coming out of it. I have a diagram but it only has 7 wires shown. The diagram works for the 7 of the 11 wires. I just need to know what the other 4 do. At first I though it might be for the hazard but that should have been done internally. When I got the truck it was just sitting on the seat with a foot of wiring and missing part of the mounting bracket. Is it possible to make a mounting bracket?
on
I think I might have figured it out:
Red = RF parklight
Green = LF parklight
Grey = LR taillight
Black = RR taillight
Yellow = flasher
Blue = flasher to light in switch?
Black w/Grey stripe = Stop light switch
Red w/Green stripe = Headlight switch dim to front parklights
White = Headlight switch to rear taillights
White w/Green stripe = LR taillight
White w/Red stripe = RR taillight
If this is correct then I can run stock single filament Ford parklights and taillights. When the turn signal is activated it cancels the headlight switch dim but leaves the other side alone. I guess I won't have to modify the stock lights to add a double filament bulb. The switch is in good condition too.
Red = RF parklight
Grey = LR taillight
Yellow = flasher
schweinhaus
05-20-2016 12:08 AM
Scotty's 52 F3
17
09-09-2015 08:45 PM
Steve49841
04-07-2015 05:38 PM
F5Grunty
05-26-2014 12:24 PM
KEITHS 1950 F68
08-11-2003 04:36 PM
