cracking 390's
Old 04-25-2004, 02:42 PM
superdutydude's Avatar
superdutydude
superdutydude is offline
Question cracking 390's
i've got a 71' f-250 and have had 3 390's crack a cylynder on me including my 500 horse motor does anyone know if this is a chronic problem, I'm building a 429 CJ know Im done with 390's.
Old 04-25-2004, 06:13 PM
mlf72f250's Avatar
mlf72f250
mlf72f250 is offline
I've heard of a few, but not many.
The folks just have them sleeved and they're good for 100k fun miles.
Old 04-26-2004, 09:39 PM
averagef250's Avatar
averagef250
averagef250 is offline
What 390 blocks are you using? I've always had great luck with 390's, but I have a 72 parts truck with a 390 that had crappy headwork and all the exhaust seats fell out. the pistons and chambers look like hamburger meat and 5 of the cylinder walls cracked. Looking closely at the cracked cylinders, the walls were paper thin and the block was only bored .030". The block was the original block from the truck (according to the original owner) and did not have the reinforced main webs. I've built several 390's using the later reinforced D4TE block with no problems. Also have many friends running the early 390 blocks with the monster main webs and crossbolt bosses, but 2 bolt mains and no problems. I've always stayed away from mercury blocks and non-reinforced ford blocks as the reinforced ones are plentiful.
Old 04-27-2004, 07:31 AM
krazmechanic's Avatar
krazmechanic
krazmechanic is offline
keith craft has a main girdle for reinforcement
Old 04-27-2004, 10:03 AM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
How much were they bored out? That can make a difference. Also, I think the FT has thicker cylinder walls, may want to check into that.
Sounds like bad luck to me.
Ketnan
04-29-2016 07:02 AM
One Ton Tuggin
07-23-2015 06:26 PM
1972fordf-100
19
12-05-2008 03:54 PM
67nukeford
26
09-11-2008 09:56 AM
Roach1161
13
08-28-2002 06:35 PM
Quick Reply: cracking 390's
