Bigger oil pans
The only thing bigger than stock that I have seen is the Milodon 7 qt for the FE. I have one on the way now, its considered a street/strip pan and is $180 from Summit. I have seen others bigger im sure I just don't remember were, and I think they were for circle track, but some one probably can correct me on that.
The Milodon may be too deep for 2wd trucks.
We've had this discussion, and unfortunately we have only found the old 9 qt big F Series pans. They stay the standard depth but all the way back. Aside from that, I think we decided you would have to make your own pan or notch the cross-member to fit some of the aftermarket pans like the Milodon or Canton.
Even the 4x4 has the front crossmember under pan, right??
That means nothing deeper than STOCK will fit. A deeper REAR sump is a possibility.
I would check on getting the FT truck pan/pickup combination. I saw one on Ebay the other week for $50. MUCH cheaper than an aftermarket pan. You must fab a mount for the pickup tube, since it runs to the back. It will need support or it will break off from vibration.
Yeah.. I'll keep the rear sump.. I found an 8qt pan for 4x4 applications, rear sump, and is meant for FE 360-428 now I just have to take some measurements to see if everything will clear. Only catch is it's $269.. but I guess when you want results price has to take a back seat. I found the pan at Summit.
Keep you posted, thanx
Madmike33
Madmike33
Madmike33
01-23-2008 12:37 AM
