Tire size change on '04 F-250 HD help!!
Hi there,
I'm from England and work for a company who imports and repairs a number of Ford Pickup trucks. I'm working on a new 04 f-250 HD and have spent the last few days changing the suspension to lower it. Unfortunately its not low enough and so my next plan is to downsize the tires. However i realise that this will make the speedometer incorrect so how can i get the speedometer recalibrated accordingly.
Thanks in advance,
Thomas.
Thanks in advance,
Thomas.
You need a Superlift TruSpeed Speedometer Calibrator.
Here is a link to get you started. Shop around for best price....
It is about $165.00 USD
http://www.ntwonline.com/acb/showdet...=1973&CATID=15
1999-2004 Super Duty F-series / 2000-2004 Excursion - Speedometer Recalibration Service Tip
To Recalibrate The Speedometer On 1999-2004 Super Duty F-series And 2000-2004 Excursion Vehicles You Must Use Ngs (cannot Be Done With Wds). Program The Abs Module Using The Following Procedure: Select Service Bay Functions; Abs; Tire Size/axle Ratio Configure; Select Vehicle; Enter Correct Revs/mile And Axle Size; Select 'n/a' For Abs Option; Press Done. To Determine Correct Revs/mile For A Tire, Divide 63360 By The Actual Circumference Of The Tire In Inches. For Example, A 91 Inch Tire Circumference Would Equal 696. Then Add Two Zeroes In Front Of It (for Ngs) To Equal 00696, This Number Cannot Be Less Than 600. For Axle Size, Select Any Option Where Tone Ring Teeth Equals 00120
ctimrun
02-13-2012 06:35 PM
jdcrew
04-29-2011 11:57 AM
paneltruck
08-16-2010 09:33 AM
